Materials
- Two 6 inch lawnmower wheels
- 3/8 inch concrete reinforcement bar
- 6 hex head bolts 1/2 inch x 2 1/2 inches with hex nuts
- 2 cotter keys 1 1/2 inch long
- 4 lockwashers 1/2 inch in diameter
- 4 squares of steel 3/16 inch thick measuring 1 3/4 inch x 1 3/4 inch
- Electric drill and bits
- Hacksaw
- Welder
- Tape measure
- Wrench
- Grinder
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
I'll sure feel better protecting those treaded feet from wearing down from the first 2-3 feet of dragging required to get it out of its storage space. Thanks Phil!
Your post got picked up on Lifehacker.com. I like the idea but for now I'm still able to carry the ladder top of shoulder style like the telephone workers do, so I'll keep this idea filed for later use if it should arise.
Keep up the good work.
Dan
Please let me know if I should give more credit
A
Only the pic of my levitation in not retouched using a magic means.
Getting the 36 pounds dynamite to sit still was almost impossible.
There I used a single inverted pin jack stand and edited the pic.
I had to use this ladder to clear branches for my giant box camera
for last week's sun eclipse.
Don't plan to move it until after Venus goes by June 5th but then those wheels sure look like the way to go for me.
A
Leave that ladder up and the neighbors are going to think that you eloped!
All that Sun gazing you're doing explains a couple things.
Iv never been in this position before.
What are the rules on asking you permission to post my copy of your Ladder easier to move ible ?
I would certainly give ample credit to your inventive skill
This was a first project that I made without ever leaving my workshop,
all the materials were at hand :)
A really handy used it again tonight...
Anyway, if you say NO then I will not post. . . A
A parts list for you:
http://www.strangecosmos.com/images/content/176701.jpg
you know how some people can't step on the crack in a side walk.
Well I can't do clutches ! I'm a really sick EE welder...
I once got upset with someone who took something I wrote that was several pages long, reprinted it word for word, and let everyone think it was all his. You are not doing that at all. Go for it with my blessing.
Make sure to coat the attachment with something to prevent the aluminium in the ladder and the iron in the rebar to become a battery, the polarisation will cause electrolysis to dissolve parts of the construction.
John
I thought about a wooden version. I would think 1 x 3 or 1 x 4 would be fine for the wheel supports. I would use a piece of plywood over the joint where the wheel axle would pass through the wood. It would make the joint more solid and would better anchor the axle bolt, too.
The wheels for the ladder do not need to carry much weight, so you could probably use thinner threaded rods through the rungs. You could always buy simple rod with no threads and buy a thread dye for the size you need so you can cut your own threads on the ends of the rods.
I hope all goes well. Thank you for looking at this and for commenting.
I had also thought of threading the end of a standard rod or even threading a piece of rebar, admittedly that might be hard to do but it is soooo cheap.
This is really a super handy idea though.
John
Thanks Phil
