3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Laptop Stand from Cardboard - The Quick and Easy Way
Step 3Measure and cut out the laptop stand's legs
Measure and cut out the laptop stand\
First, I measured out the 15 1/2 inch length of a leg, then the 5 inch rear height of the leg. I wanted a "block" at the front edge to keep the laptop from sliding off the stand, so I measured out a small rectangle 2 inches high at the front and 1 3/4 inches in from the front. On this last line, I marked off a point 1 inch from the bottom. Marking a line from this point to the 5 inch point at the rear gives us the cut lines for one leg.
You can repeat these measurements for the second leg or use the first leg as a pattern.
1 comment
Jun 24, 2010. 7:14 PMcyber-hatter says:
could draw out a diagram to label out the measurements I'm still mixed up from the measurements of the distance away from the table and height of the LCD of the laptop.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:billr
