Introduction: Make a Leather Cuff Bracelet From an Old Belt
This tutorial is going to show you how to turn an old leather belt into a cuff.
I have seen so many awesome leather belts at the thrift store, but most of them were not my size. This project gives me a whole new outlook on leather belts... just turn it into a cuff!
Step 1: What You Will Need
What You Will Need:
-Leather Belt
-Snap Fasteners Buttons (at any craft store)
-Setter & Anvil (Comes in Snap Fastener Button Kits)
-Rotary Hole Punch
-Scissors
-Mallet or Hammer
-Something to hammer on, like a cement surface with a hand towel on it
-Pen or Sharpie
Step 2: Lets Begin
1. Start by wrapping the belt around your wrist.
Make sure it is fairly sung.
Give yourself 1 1/2" of extra length.
2. Cut the belt.
Another Option:
You could also measure your wrist, add 2-3 inches,
then measure and cut your belt.
Step 3: Punching the Holes
For the Top Snap:
Right Side up, on either end of the belt ,go up a 1/2"-1" and
punch out a hole.
Note:
Start by using a smaller punch first.
You want the snap to be snug in the hole.
Try to slide one of the snaps into it.
If it definitely wont fit, go up one punch size.
For the Bottom Snap:
Once you get your top snap fastener in (see below) wrap the bracelet around your wrist again
and make a mark where you would like the bottom snap to be.
Punch out the hole.
Step 4: Putting Your Outside Snaps On
Do your outside snap first.
Note: Make sure you hammer in the first snaps before punching out the hole for the second set of stamps (step 7).
This is going to make sure your cuff will fit properly.
The outside snap will have the shiny button-like top.
Please refer to the directions in your book if you become confused.
Here is how you will layer the first set of snaps:
1. Top Snap (has ridges on the bottom)
-Push the top snap into the top part of the belt, the side with the print. Flip it over and add the bottom piece
2. The Belt will be in the middle (the belt should have a hole in it)
4. Bottom piece (it is the one that has the ring inside of it)
-This piece goes on the wrong side of the belt.
5. Anvil (what you will be hammering the snaps on)
Step 5: Second Set of Snaps
This is how you will layer the second set of snaps.
The second set of snaps are the opposite of the first ones.
- The snap that has a point goes through the bottom of the belt.
-Then the snap goes over it on the right side of the belt.
-The Anvil will be on the bottom scoop side up.
Step 6: Hammering the Snaps
Now comes the setting of the snaps.
You are probably wondering how they are going to stay since they are too big.
After you hammer them in they will cozy up to your belt.
Find a very hard surface, like concrete, and lay a towel down so you dont scratch your buttons.
1. Lay the Anvil down scoop side up
2. Lay the round button top end onto the Anvil3
4. Place the Setter point in the hole. Hammer the hole down with a few good hits.
If the snap is wobbly you need to hammer it a few more times.
You want the snap to be snug.
Do this to both sides.
When you are finished cut off any extra belt that is left over.
Step 7: YOU'RE FINISHED!
Enjoy!
If you liked this project, check out more of my tutorials here: korrinewojcik.blogspot.com
Happy Crafting!
