Introduction: DIY Lego USB
In this instructable I will show you how to make a mod and make a Lego thumb drive, so get out your old Lego collection and start building!
You Need:
-Thumb Drive
-Lego bricks
-Super glue
-Razor blade
-Dremel
You Need:
-Thumb Drive
-Lego bricks
-Super glue
-Razor blade
-Dremel
Step 1: Taking Apart Your Drive
First, take apart your thumb drive by cutting it open with the razor, then take the drive part out (without breaking it), and size it up to a Lego brick to determine what size you'll need. Then, head to your work place for the rest.
Step 2: Modding the Lego Brick
Now get out your dremel or drill and drill out all the insides of your Lego brick, leaving only a "trough" which your drive will go.
Step 3: Sanding Down
After your Legos insides are out you're going to sand it down to the size of two flat Legos, so stack two flat Legos on top of each other and trace a line onto the brick where your gonna shave off, look at the pictures for more help. I used a dremel to sand the brick down, on my first one a used a file but that took almost an hour. Amost Done!
Step 4: Making the Drive Fit
My drive didnt fit in the Lego brick so I had to widen the sides, so I took a drill to the sides and made it a little wider (You are most likely going to have to do this). Then, cut out a slot for the drives metal thingy.
Step 5: The Bottom
To finish your drive, take a flat brick and shave off all but two of the dots (this makes it so the bottom will fit into the other brick better) so your drive will fit, then simply glue the bottom piece onto the hollowed out shave down brick and your Done!
Step 6: Finished!
Here is the finished product.
Ask if you have any questions
Enjoy!
Enjoy!
