Introduction: Make a Lie Detector Machine With ElecFreaks Micro:bit Tinker Kit
Picture of Make a Lie Detector Machine With ElecFreaks Micro:bit Tinker Kit
With this machine, the truth will never escape you! As long as you can make your subject hold a moisture sensor for a while.
This tutorial was contributed by Samuel Ong from Raffles Institution.
In this project, we will create a simple lie detector machine, which works by measuring the electrical conductivity of our skin. Upon feeling nervous, our skin's electrical conductivity will increase, and the moisture sensor can pick up on that. This allows us to determine if a person is telling the truth or not.
Step 1: Materials:
Picture of Materials:
1 x BBC micro:bit
1 x Micro USB cable
1 x Breakout board
1 x Octopus OLED
1 x Moisture Sensor
Tips: If you want all components above, you may need ElecFreaks Micro:bit Tinker Kit.
Step 2: Goals:
Get to know the Octopus LED and Soil Moisture Sensor
  • Learn basic statistics
  • Make something using the moisture sensor
  • Step 3: Procedure
    Step 1 – Components
    First of all, plug in the soil moisture sensor. Match the colors and note down what pin you plug for it will influence later procedures.
    Next, plug in the Octopus LED. Any of the three slots should do.
    Step 4: Procedure
    Step 2 – Pre Coding
    We'll need to add a package of code to be able to use our kit components. Click on "Advanced" in the Code drawer to see more code sections and look at the bottom of the Code Drawer for "Add Package".
    This will open a dialog box. Copy and paste the following link into "Add Package" text field: https://pxt.microbit.org/50544-64675-33322-24641. Click the search icon or press enter, then click on the Tinkercademy button.
    Note: If you get a warning telling you some packages will be removed because of incompatibility issues, either follow the prompts or create a new project in the Projects file menu.
    Step 5: Procedure
    Step 3 – Coding
    First of all, initialize the OLED using blocks in the OLED section as shown in the picture
    This part of the code allows the soil moisture sensor to measure and record down the electrical conductivity between the two fingers every few seconds for about a minute. Then, it calculates the average. This is the "calm" value when the user has not told any lies.
    This part of the code calculates the standard deviation of the readings obtained in that first minute. The standard deviation indicates how different the readings were. A larger standard deviation means more variance in the readings. The "Math.sqrt" block square roots the given value and was added in JavaScript.
    After the initial readings have been made and recorded, the moisture sensor now measures the average electrical conductivity over five seconds. If it is higher than the average added to the standard deviation, we can conclude that the user has an abnormally high electrical conductivity and is thus lying. Then, the LED screen would show an "X" shape.
    To relieve your tired fingers, you can download the code below:https://makecode.microbit.org/29019-49351-22059-80...
    Step 6: Procedure
    Step 4: Using It
    First of all, you will have to attach each prong of the soil moisture sensor to one of your fingers. Personally, I found that using rubber bands was a simple and effective way to do so. You can experiment with different methods, such as using crocodile clips or tape.
    Now, turn on the device. The device will record the electrical conductivity of your skin under calm circumstances. Then, it will give the average value and its standard deviation.
    After the initial readings have been made, ask again! If the person has lied, he will become nervous and the device can pick up on that, resulting in a cross being displayed.
    Step 5 – Success!
    Voila! Now you can test lies with this machine easily.
    This article is from Tinkercademy Basic Lie Detector.
    Step 7: Relative Readings:
    Step 8:
    HaiT28 (author)2017-09-27
    what if the subject sweats due to anxiety
    About This Instructable
    885views
    21favorites
    License:
    Bio: ElecFreaks is an open design house founded in March 2011. Our goal is to create rapid prototypes and give small-batch manufacture solution for makers and ... More »
    More by ElecFreaks:Elecfreaks Motor:bit User GuideCreate an Electric Spirit LevelHC-08 Bluetooth UART Communication Module V2.4 User Guide
    Add instructable to:
