Step 4Tunic, Hat, Leggings, & Undershirt
- Green Fabric (how much you need depends on your measurements)
- Sewing machine and thread
I used this pattern I found online for the tunic.
www.angelfire.com/ia2/barony/newmembersguide/sewingtipstxt.html
It's very straightforward and simple. Just make it a little bigger than your measurements, especially if you're a girl. I had a bit of trouble fitting into it without popping a seam. Cut yourself a neckline, and make the front box-shaped. For the hat, I used scrap fabric from the tunic. Measure around your head where you want the hat to sit, divide it by two, and then add an inch or two, depending how loose you want it to be. Make that length the base of a triangle (make it however long you want), and cut out two pieces. Sew them together, and you have a hat.
For the undershirt and leggings:
- A white turtleneck
- White leggings
- Eyelets and whatever the tool to put them in is called..honestly, I don't know what it is. A plier-like tool..
- Brown Dye or Tea Bags
- A Shoelace
For the turtleneck, I cut off about half of the neck so it went up my neck a couple inches. I cut a slit down the middle of the neckline, and hemmed the whole thing. I put four eyelets in (two on each side of the neckline), and laced a shoelace through them. I then followed the instructions on the back of the bottle of dye, but I used the tiniest amount of dye in relation to the amount of water I had, so that my fabric dyed to an off white, rather than brown. You can dye your fabric using tea bags as well. So, dye the leggings and turtleneck, and then let them air dry. After that, mine were a little too dark, so I washed them in the washing machine, and then put them in the dryer.
Add Comment
