3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Microbial Fuel Cell (MFC) - Part II
Step 5Charging and Operating
Dayyum, that septic tank stuff stinks...You're going to want to do this outside or in a well ventilated area.
Pick on chamber to be the anode (microbe) chamber and one to the cathode chamber.
Fill a measuring cup with about 2 ozs of warm water and add salt to it until no more will dissolve ( a saturated solution ). Stirring and shaking will help. Allow the water to completely cool. Remove the sponge slices from the cathode assembly and make sure they are thoroughly soaked in the salt solution. Pour the rest into the cathode chamber until only the salt slurry remains. Place the carbon electrode on top of one sponge, cover gently with the slurry and then use the remaining slice to complete the sandwich. Place this gently back into its connector and insert into the cathode tube. The tube will overflow as the cathode is inserted, That's okay we want the carbon electrode to come into contact with the air so pour off a bit of water as well.
Fill the anode chamber 1/2-3/4 full of the septic tank treatment. I also added a couple of teaspoons of sugar and some shredded paper to provide carbon and nitrogen. Fill the chamber the rest of the way with pure, dechloronated water. Inser the anode assembly fully into the anode tube.
I began measuring voltage on the open circuit. Within 15 minutes I was generating measurable voltage (82 mA). Once the output voltage seems to stabilize I will measure under load and update.
20 comments
Mar 8, 2010. 8:52 PMkrishnamohan says:
Hi,I prepared a micobial fuel cell of approx 1.7 lts with agar salt bridge and carbon/grapite electrodes and waste milk as fuel. I started watching the current from the 2 day of setup with a peak voltage of 0.6 V and 0.5 mA. Could you please suggest me how to optimize it interms of salt bridge , should I go for Nafion membrane. The agar bridge is of 2 inch thickness,so will it make difference if I switch to nafion and do it affect if I add Hydrogen Peroxide to cathode chamber.Please help me out any other ideas if u have.Thank you!!
Mar 11, 2010. 3:47 AMkrishnamohan says:
Hello sir
As you suggested to use YEAST, I have a doubt that , whether it requires a MEDIATOR or not.If yes, please let me know, which one is the best.
An interesting thing, I observed in my setup is, it  produced peak voltage and current with in 5 days of setting it up, and it started reducing.For 30 days it showed the reducing phase, but for the past one week it started rising again and now to my surprise, it gave me a voltage if  0.5 v and 0.8 mA ( on march 11, 2010 ) , which is highest of my reading till now, I hope it is going to increase more.
Aug 12, 2011. 8:02 AMsattarga says:
hello sir,
i'm from from and i want to do project in my college in mfc. as you've done experiment in mfc it will be so kind of u if you tell me what are the thing necessary to create an mfc what is the bacteria you used and where can i get it.please help me sir thank you.........
Nov 4, 2009. 4:58 PMleecho0 says:
hi would you be able to make something like this:
http://www.economist.com/sciencetechnology/displayStory.cfm?story_id=14743791
with this 'ible? what would you need to change to make the salt bridges semipermeable to only one kind of ion?
Nov 5, 2009. 10:54 PMleecho0 says:
 nafion would only work for the cation exchanges, right? what would you use for the anion bridge?
Aug 31, 2009. 4:55 PMlendogg says:
i constructed a quick version of this using two mini pie tins as electrodes and cardboard saturated with salt as the salt bridge using river mud id made 0.5v 100-200ma intreastingly i got a simeler output from clear river water taken from the surface
Jun 24, 2009. 5:27 AMJavin007 says:
I would be very interested in seeing what kind of voltage and amperage you get out of one of these units. I ask, because I've only been able to find one place on the internet that mentions voltage and amperage from a Microbial fuel cell, and the amount of energy put out on that one is around 1/72000th of what a AAA puts out. At least for their purposes, the cost of energy used to create the fuel cell (heating the water and the hot glue gun alone, not even taking into account the production of the PVC, chemicals, etc. ad infinum) resulted in one of these cells requiring literal millions of times more energy to create than they would ever produce. I would be interested in seeing if anyone has created one with a decent energy output, or if these are more of a school science experiment type of thing.
Jun 26, 2009. 11:44 AMJavin007 says:
If I'm understanding your math correctly, it would take almost two weeks to produce the same amount of electricity that's in a single AAA. This is also the equivalent of 32 AAA batteries in a year (assuming that this can run non-stop for a year with no additional resources.) I think (just guessing)the electricity used to create the PVC piping (melting plastic, shaping, etc) as well as any other resources used to create the product (chemicals, filters, etc) would significantly outweigh the electricity it produced unless it was kept running non-stop for many, many, many years. Compare the 57W per year with the 3000W per hour of a home generator that runs on gasoline. Even running on a fossil fuel, the home generator would be far, far more "green" than one of these devices. Even more so if the home generator is running on ethanol (which can be made at home). In order to create the same amount of electricity that you would get from a home generator, you would have to build 454,546 of these devices (running at peak efficiency according to Logan at Penn State) running in serial. Half a million of these devices would be many hundreds of times more damaging than a single $300 generator. I think when you consider the impact to output ratio, this device is actually quite "un-green" in the long run. Now, if it were made (which it could not be) 100% out of stuff found in a landfill, it'd be a different story. But the production of the necessary chemicals alone would be enough for me to consider this device (and many like it, I'm not specifically trying to pick on you) to be "dirty" energy.
Jun 24, 2009. 7:47 AMbobtannica says:
I will be eagerly watching for further developments! Thanks again for the great 'able.
Jun 20, 2009. 11:55 PMbobtannica says:
Fascinating 'able you have here. Can I suggest a few more pictures re the charging and operating section? Could these be hooked to others for more power? (in series or parallel?) Are there temperature parameters? (Min/Max) Approximately how long will this last overall, not just between "feedings". Really interesting and thought provoking. Thanks for your effort and sharing!
Jun 21, 2009. 7:35 AMbobtannica says:
I guess my only concern with using nafion is sourced at the same place as my "affection" for the gelatin salt bridge that you concocted. It is readily available to the common man, such as myself. I certainly applaud any and all efforts at scaling this up and making it usable for the general population, however, I love the instructability of your alpha. Thanks again.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
155
Author:egbertfitzwilly(More about me at LinkedIn....)
