3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Microbial Fuel Cell (MFC) - Part III
This 5 gallon single chamber microbial fuel cell uses inexpensive conductive cloth to provide a silver catalyst and a styrofoam permeable membrane.
Operation of a single chamber MFC is complicated by oxygen poisoning resulting from the conflicting requirements of the anaerobic population and the cathode requirement for dissolved O2. This design attempts to limit oxygen poisoning by using a brush type carbon electrode combined conventional carbon paper to provide a gas barrier without limiting free flow of the microbial medium.
The use of styrofoam as the permeable membrane is novel as far as I can tell.
Conductive cloth is used to provide an inexpensive silver catalyst to promote oxidation at the cathode. We use silver plated conductive cloth from lesseremf but any silver plated material should do. The use of silver as a catalyst is based on the research done for the air cathode in an aluminum air battery and is experimental in an MFC.
As you can see from the picture I got about 90 mV across the open circuit after charging and assembling the cell. The extraction of power from an MFC scales directly in proportion to two things, population density and surface area of the electrode surface at the cathode and anode.
Power will continue to rise as the population density increases.
Step 1Bill of Materials
Bill of Materials
This is a simple bill of materials and assembly. Because we are building a single chamber MFC we won't need to create a salt bridge or anything like that.
1 5 gallon plastic pail with lid - I got my mine at Home Depot on sale for $2.97 plus the lid
8 in styrofoam disc - Cut out of packing material or I'm using one I got at Michael's
Use loose styrofoam if you can get it. You want air to pass easily through
Anaerobic Microbial Culture - I'm using "Microbe Lift" brand Septic Tank and Cesspool Treatment
Yeast should also work
1 Package of large aquarium charcoal filter pads. I'm using Fluval brand 4 PLUS filters
Silver coated conductive cloth - http://www.lessemf.com/fabric.html I'm using the "Stretchy silver coated sheer nylon weave". This is used as a catalyst to facilitate oxyidation at the air cathode. It also as the electron collection grid.
A couple of wire leads with clips or some way to attach them to the carbon pads.
Two sheets of carbon paper. This is used to get good mechanical connectivity between the pads.
26 comments
Aug 28, 2010. 8:54 PMDr Qui says:
Please don't take this question the wrong way, I'm not trying to disprove the concept just curious.
Is it possible to power any electronics as is or would you need bigger or more of them?
Is there a large scale application?
Aug 29, 2010. 9:12 PMDr Qui says:
I'm kinda baffled by it.
Does the yeast culture feeding on the paper and sugar from the soda make an electrolyte type substance that powers the cell?
Would it be more efficient at the equator than saw Canada or Ireland?
You are indeed a scientist, you work is pure science, much cooler than anything they ever showed us at school.
The best science and technology comes from men in sheds who often make groundbreaking discoveries.
Mar 4, 2010. 3:57 AMCoolKoon says:
How about the current? And since many months have passed since this assembly, how much energy have you managed to extract from it (Wh or something)?
Mar 7, 2010. 5:54 AMCoolKoon says:
Yeah, I'm even kinda surprised you've managed to separate the two processes, as that's kinda hard to do with off-the-shelf materials. This reminds me of the process of making sour cabbage (a local delicacy I guess), where you shred the cabbage, but it into a barrel/vat, add some salty water, cover the whole thing with a plastic bag and press it down for better seal (my grandma used a big rock for this). I know that the fermentantion process that takes place there is anaerobic (the bacteria involved use nitrogen in their metabolism instead of oxygen IIRC), and it's relatively slow (it takes a few weeks for the cabbage to turn sour). What I still don't get though is the need for dissolved O2. I thought that the only thing you need in an electrolyte are ions (molecules that will act as charge carriers) or am I missing something?
How did this two chamber model of yours perform then?
Mar 7, 2010. 2:28 PMCoolKoon says:
Hmmmm.......this goes contrary to much of the stuff I've learned about the chemical reaction involved in my chemistry class (hmmm........quite a few years ago). I mean water is a dipole molecule, which is caused by the big electronegativity of the oxygen atom (it almost strips the H atoms of their lonely electrons and keeps them for itself, making the O part negative). Therefore when you dissolve something in water, it's actually "disassembled" by the water molecules into positively and negatively charged ions. Take for example table salt: the water molecules separe it to H+ and Cl-. This separation remains while the water molecules are present.
A salt bridge is usually used to facilitate ion exchange between two separate electrolytes. You see the charge carriers are not the water constituents but the ions dissolved in it, otherwise some distilled water could work as an electrolyte too (without prior charging, of course). I'd say that the charge carriers (ions) give up their electrons by merging with the materials of the electrodes itself. Now I'm sure things are a bit different when microbes are involved, but I don't know much about the mechanics involved. So the question remains: if the microbes can survive only in an oxygen-free environment, what's the O2 there for?
As for the sour cabbage electricity thing I thought about that too. Unfortunately my grandma passed away about a year ago as the result of a final stroke. She never recovered fully even from their second one though (wasn't the same person anymore), but have I tried that before (attaching electrodes to sour cabbage and testing it with my multimeter) she would've surely been convinced that I've gone crazy and banned me from the basement (by hiding the key) :P No sour cabbage has been for a long time (probably for practical reasons as well, because it wouldn't be eaten I guess) so I don't think I could try it out (especially because none of my parents like my experiments either :S). Still, it's a really interesting idea that's worth a try.....
Oct 31, 2009. 7:24 PMAwesomeD says:
where does the 1st lead go
Jan 2, 2010. 5:36 PMbobtannica says:
Egbertfitzwilly, you have done it again. Fascinating! A corollary question to AwesomeD's... I am assuming that the leads connect to the silver mesh but in the top electrode there are two layers of mesh... In this case, is it one or both pieces of mesh? If one, does it matter which one?
  I also have another pair of linked questions. Re the shredded paper; you state to "put in the rest of the shredded paper" but haven't told us to add paper before that. Did I miss a step? In all, about how much paper do you want us to add?
  I am just full of...er...questions. Are you using the liquid or granular microbe lift? And finally, what kind of power output did you see with this?
  Thank you for all your hard work! Again, fascinating!
  Wait....one more..."next generation wind turbine"??? Haven't seen you post THAT on here!!!
Jan 6, 2010. 1:56 AMbobtannica says:
Well, I am indeed missing something. To quote you from step 2, when you are constructing the top or Styrofoam cathode you say,  "As you can see in the picture it is a sandwich. The bottom layer is Styrofoam, next is a layer of conductive cloth, then two carbon pads laid side by side. This is followed by another layer of conductive cloth, then the carbon paper. "  You seem to be indicating two layers of conductive cloth(mesh) on this top layer. Do you connect the alligator clip to one or both? Thanks.
Aug 16, 2009. 12:06 AMmhkabir says:
how much voltage does it pump out?
Jul 27, 2009. 10:29 AMpuppylinux says:
(removed by author or community request)
Jul 25, 2009. 6:24 PMconrad2468 says:
I sure wish these werent so inefficient! Great instructable i just wish the technology was a little more advanced!
Jul 27, 2009. 10:35 AMpuppylinux says:
Jul 27, 2009. 8:11 AMhopenui says:
This is awesome. First time here. Reading all other know-how
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
155
Author:egbertfitzwilly(More about me at LinkedIn....)
