Make a Minecraft 1.8.0 Bukkit Server on Linux
Published
Introduction: Make a Minecraft 1.8.0 Bukkit Server on Linux
Hello world
I'm going to show you in this instructable on how to become a minecraft 1.8.0bukkit server in linux.
Step 1: Download Bukkit
I have downloaded my bukkit on http://tcpr.ca/ because on the official site of thebukkit downloads blocked and there is no download for 1.8
Step 2: Create a Directory for Bukkit
place the downloaded file in the folder bukkit.
Then create a sh file with the following:
#!/bin/sh
BINDIR=$(dirname "$(readlink -fn "$0")") cd "$BINDIR" java -Xmx1024M -jar craftbukkit.jar -o false
(if you do not want cracked players on your server can then replace false to true)
Name the file start.sh
Step 3: Make the Sh File Executable
Open a terminal and type chmod + x/start.sh in order to make the sh file executable
Step 4: Run the Server
Open a terminal and go to the directory with cd for bukkit.
Then type./start.sh to start the server. Wait a moment and then closes the terminal.
Step 5: Accept the EULA
Open your file manager and navigate to the folder for bukkit.
Open the eula file .txt. Replace false to true to accept the eula. Save the file and close it.
Step 6: Run the Server.
Then type./start.sh to start the server. IMPORTANT:D'ont close the terminal!!
Step 7: See What Your Ip Address Is
Open a browser and go to: http://whatismyipaddress.com/.
In my example is my ip address 213.229.73.216. Write this address.
Step 8: Port Forward the Server.
I can't explain how to do this.
This differed from router to router and modem to modem. Go to http://portforward.com/and search the model of your router/modem on. Follow the instructions and send port 25565
Step 9: Test the Server
Open minecraft and go to multiplayer.
Click Connect and enter localhost in directly. Other players must instead of localhost is the ip address that you wrote down in step 7.
    • Pets Challenge
      Pets Challenge
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    5 Comments
    There is no eula.txt file anywhere in the zip file being discussed here. This tutorial needs to be updated, or removed.
    I do not see a eula.txt file anywhere in the installation directory. Really doesn't make sense why you would start the server, stop it to change a configuration in a separate file, and then restart the server.
    I am trying to run a bukkit server on centOS without a gui, how would I do this?
    You can try to install a GUI and remove it after the server is running
    Nice to know that you can still play minecraft even if you have an alternate operating system. Thanks for sharing your joy bringing knowledge!
