loading
Step 6: OPTIONAL: Maintaining appearance
This step is optional, and is just to maintain the original appearance of the outside of the Tactical Light.
First take the head of the + Sign piece you cut off, and remove the ring of plastic on the inside. after you are done doing that, screw it back onto the Lens piece. then place this in its original place and over top the laser device.
Hey just in case you didn't realise... The mag in the stock goes the other way round so no need for the tape lol
nice is ur recon modded if not check out mine its MASVREV13's AR15 armorlite.
You sure do a lot of advertising, don't you? You may one day have a career in marketing.
Nicely done, what did you make the sling out of on your Recon?
Looks like a guitar strap
how do you keep the laser button on at all times? i have to press mine :(<br />
Can someone do me a favor and tell me how to make or where to get attachments for the raider CS-35? I finally got mine but it's harder to aim. So if you could post where to get or how to make any kind of attachments, dot sight, flashlight, crossheir, anything, I would very much appreciate it.
Hi nice tip and I've done that and it works&nbsp; but the only problem is that the laser pointer is not as bright and before it was modded, could this be due to the batteries as the laser pointer is using 3x 1.5 button batteries.
thanks for this man i have been wanting to but i laserpointer in the nite finder because one of my friends did it now can shove it in his face that i can have it on any gun.
I LOVE THIS,I HAVE 2 OF EACH.SO I BROKE ONE OF THE TACTAIL LIGHTS AND THEN I HAD TO GO TO WALMART AND BUY ANOTHER ONE LOL. I LIKE THIS MOD A LOT
you don't have to yell<br />
Thanks for the Instructable! Could I integrate a LED instead of a laser pointer?
This is pretty cool but i would've probably duct taped this under a maverick or any other shorter barrled nerf gun good mod though!
Wouldn't this work better in the Recon CS-6's 'Dot sight' attachment? The Tac light would be better for say, a higher powered modification than a complete removal/insertion of different lights. Then again, it can prove tricky with the CS-6 sight, as it's smaller. Harumph.
As the Tactical Light is larger, and has easier wiring, it would make sense to take full advantage and do the Best You Can. However, I decided to go in the direction of the Best You Can, on Budget. this Instructable costs less then 15 dollars, where if you were to buy a high powered laser pointer, or laser diode, it would hike up the price and make it harder for the average person to enjoy this mod.<br/><br/>On a second note, the Recon's dot sight instructable I have yet to post up. First of all because the internals are different and would change the method and possibly budget of the mod, but mainly because I would like to preserve the attachments ability to serve as both a laser dot sight, <em>and</em> tactical light, which I have yet to find a way to do.<br/>
Nice, very detailed, and effective.
COOL I have always been wanting to do something like that! >:D
About This Instructable
40,126views
14favorites
License:
More by kingkaiser:Ikea ROTERA Lantern Lamp Retrofit a Laser Pointer to a Nitefinder Make a Nerf Laser Targeting System from the Tactical Light
Add instructable to:
