This is not an Instructable for a particular device or circuit. I'm using the circuit I made for an Artbot project as an example. If you need a quick and dirty way to fashion a pc board, you can cut out the copper clad with a Dremel tool. Just plan you circuit and cut away copper to form your paths. No etchent, photo plotting or even drilling needed in some cases. Of course, you can't do any real fancy and do complex circuits, but for something simple, this does the trick.
Step 1Layout your circuit
Use a sharpie to draw where you want to cut the copper clad.
Your circuit layout looks similar to the Magbot or sun swinger circuit. You could do away with the hall effect and PIC, and make it solar powered. Pick up a copy of "Junkbots, Bugbots, and Bots on Wheels" or if you just want the circuit and description, download the manual at Solarbotics.com
I've build a couple of them free-form BEAM style as gifts and they have never failed to impress.
http://www.youtube.com/watch?v=_hwHTeuX6Qk
Check this site for more info about PC milling
http://en.wikipedia.org/wiki/PCB_Milling
