Introduction: Make a PVC Bow
Picture of Make a PVC Bow
This bow can be made in under 10 minutes for under $10 but can lead to hours of fun.  David Hughes taught me this so all credit goes to him.
Step 1: Materials
Picture of Materials
4-5 ft. 1/2 in. pvc
100 lb. parachute cord
1/2 in. pipe insulation
Two 1/2 in. pvc end caps
duct tape
Step 2: Tools
Picture of Tools
Hack Saw
Knife
Lighter (for cutting frayed ends of para cord to keep them from fraying)
Step 3:
Picture of
Cut a 1/2 in notch in one end of the pvc
Step 4:
Picture of
Knot one end of the parachute cord (burn the end if it is frayed)
Step 5:
Picture of
Place the knotted end of the cord into the notch you just cut
Step 6:
Picture of
Stretch the cord to the other end of the pvc to make a straight line.  This is so your notches will line up.
Step 7:
Picture of
Cut a 1/2 in. notch at the other end of the pvc
Step 8:
Picture of
Place the end of the pvc which has the knotted parachute cord in it on the ground, using the side of your foot to hold it steady.  Press down on the top end of the pipe and bend the pipe to the desired length.  Cord should be about 6-7 inches from the bow in the center for proper draw length and weight for most youth.
Step 9:
Picture of
Use your hand to measure a length of pipe insulation and cut it for the grip with a knife.
Step 10:
Picture of
Balance the pvc on the end of your index finger to find the middle.  You can also use a tape measure if it is easier.
Step 11:
Picture of
Slide the insulation onto the open end of the pipe.  The top of the insulation should be right at the center of the pipe with the grip being fully on the bottom half of the bow.  This is so the arrow will shoot from the center of the bow.
Step 12:
Picture of
Tape the insulation (grip) with duct tape.  Start at the end where the arrow will rest but leave the very top surface exposed so the arrow has a ledge to rest on.  Tape it tightly, spiralling downward, taping the bottom portion to the pvc itself.
Step 13:
Picture of
Knot the other end of the cord, bend the bow, and insert the cord into the notch.
Step 14:
Picture of
Shove the end caps onto both ends of the pvc to secure the parachute cord.  I suggest placing the cap on and then put the tip on the ground and use your wight to make sure it is secure.  You can even pound it on the floor if necessary just to be sure it is on tight.
Step 15:
Picture of
Have fun!
james.oden.10 (author)2015-01-10
If you would like to increase the draw strength without increasing pipe diamater than you might substitute Schedule 80 pipe(it's stronger too)
Mythology Geek (author)2014-10-30
cool
subrata.mondal.758737 (author)2014-08-24
No one can brake pvc bow of perfect draw length 1_1÷4 inch schedule 40 pvc pipe of 56 inch can be turned into 80 pound bow what I use. 1.5 inch pvc can make even more what I have 1 but I cant draw it fully. Also u can give a awesome look like wooden finish etc. But one has to make it properly look for backyard bower on youtube. Its a new idea and we shall appreciate it. Because many great ideas were lost because of our ignorance and inappreciation.
knexbug (author)2014-06-15
you should heat it before bending so it wont break
bwh13 (author)2013-10-26
Don't pull back too hard! That bow looks like it would shatter under that kind of strain. It'll fly apart right where you're holding it.
About This Instructable
3,914views
50favorites
License:
More by Kentexan:Make a PVC Bow
Add instructable to:
