Make a Pen Without a Lathe
3,777
78
23
Posted
Introduction: Make a Pen Without a Lathe
Runner Up in the
First Time Authors Contest 2016
I wanted a pen for myself as I am a woodworker I thought it would be wise to make a wooden pen. Unfortunately, this led me to the new problem of not owning a lathe. But I have made a point of never allowing a lack of tools to stop me from making something. I am going to make a pen without a lathe.
Step 1: Drilling Out the Pen Blank
I started by ripping down some White Oak to three-quarter inch by 3 quarter inch pen blanks. After some experimentation to find the correct drill bit for the end kit shaft to fit into, I was able to bore the holes through the pen blanks with a brace. this hole was the same size of the Pen tube OD.
Step 2: Drawing the Shape
I wanted to shift to be a hexagon so I found a nut with the appropriate size and used it as a pattern to trace on one end of the pen blank. This gave me a point to which I can plane it down without going over that line. I found that if I put the nut on a bolt and then put the bolt in the hole it would center the nut and give me equal distances from the sides of the hexagon to the center of the pen blank.
Step 3: Plane to the Lines
Next, I put the pen blank into the vice and started planning it down to the lines that I marked with the none. This took about 16 minutes per blank but went fairly quickly as it was an enjoyable task. I started planning down to the line on my end. Then, I would flip the blank end for end and plane down the other end to match the end I already did.
Step 4: Rounding Ends to Match Pen Kit
After shaping them I needed to round the end slightly so that they would join the pen pieces smoothly. I did this with a file counting how many strokes I made on each side so that there would be an equal amount of rounding on each side.
Step 5: Finish Pen Tubes
The finish on the pen is wipe on poly. I lightly sanded in between each coat with 400 grit sandpaper, and then finished off with a light coat of poly. I found if you set them on screwdrivers or in my case dividers they were easy to hand finish.
Step 6: Press the Pen Together
To press the pen together I used my bench vise.You have to be careful to make sure everything is perfectly lined up before pressing it, but with a little care, it works very well.
Step 7: Step Back and Admire Your Work.
I was expecting the pen to be uncomfortable but with 6 sides it really feels good on the three fingers that rest on every other side. In the end, I am extremely happy with how this came out. A lot of joy to make, and a great pen I will enjoy for years to come. If you want to see more here is a link to the video showing the whole process.
  • Metal Contest 2017
    Metal Contest 2017
  • Wheels Contest 2017
    Wheels Contest 2017
  • Remote Control Contest 2017
Questions & Answers
23 Comments
Loved it on YouTube and love it on here. Great job, James.
thanks man! and thanks for the great encouragement and ideas for improvement.
very nice, I like the camo look of the wood. Any ideas how I can make one without using a plane nor a lathe? I don't have either.
You could do it with a rasp and sandpaper. Slower, but it'll still work.
Thanks man. the first one I made was with little more than a chisel. here is the video of back when I built that. https://www.youtube.com/watch?v=YvVnZX7hpg0
A great alternative to turning a pen it turned out real nice well done
Thanks! but it did not "turn out" LOL sorry I could not resist!
nice one I love the figure in that oak !!
thanks man!curly oak is one of my favorites.
I saw your YouTube video, now I'm inspired to try it. did you consider using a spokeshave to create a round profile?
