Uses:
-Pressing against someone's arm, pulling back, and firing the end of the chop stick into their arm.
-Put a third or fourth of a shop stick down the "barrel" of the Pencil Cannon and fire it and have a war with friends
***WARNING***
May cause bodily harm if aimed at a person. Take extreme care of what/who you aim at. You may have this weapon, but they have their fists and may beat the hell out of you.
If you use this at work you could get fired.
If you use this at school you could get suspended/expelled.
Use at your own risk.
***WARNING***
Remove these ads by
Signing UpStep 1Materials
-A mechanical pencil. (For the barrel of the cannon)
-Two(2) Rubber bands.
-One(1) Chopstick.
-One(1) to Two(2) Twist Ties. (Can be found at most grocery stores, near the produce, such as tomatoes, carrots, corn, Etc.
-One(1) Pair of Scissors.
-Common Sense. (Which is not too common...)
If you would like to make wooden projectiles you will need the following:
-Another chop stick.
-A knife.
Also, if you would like to color the chop sticks, I would recommend using Sharpies.
comment
Add Comment
Add Comment
