3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Pencil's Lead Potentiometer (Experimentations)
Step 4Testing With LED - Assembly
You can also test the Variable Resistor with an LED. Here is how to do it: First connect your 2 alligator clips to the 9V (one on each pole), then connect the Negative clip to the negative lead of the LED, and finally, bend the positive lead of the LED(Anode, the longest) so its easy to move on the paper and it gives good contact. ( If you don't have any alligator clips, you can replace them by normal wire, simply twist around the components to make the contact, or solder ) *Tips : If you don't know witch lead of the LED is - or + , test out with a button cell !
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:Patented(Youtube Channel)
Hey I'm Nick, I come from Quebec in Canada, I'm passionated by a lots of things, Such as every things electronics or mechanic! I like to understand how stuff works and I also like to discover new thin...
more »
