Make a Plywood Portrait Monitor Stand
 by DanNixon
Featured
Step 6: Further Modifications
When I assembled the stand and tried to use it with my monitor for the first time I found that the fact that the two foam "feet" protrude mainly in the centre of the base meant that it was very unstable, so I modified the base by drilling four 40mm holes in each corner and placing an extra foam disc in each one, protruding slightly more from the base than the two in the middle of the base, this helped to solve this problem.
The foam discs were cut using a laser cutter and held in place using double sided tape.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
