Make a Portable Camping Shower
17,003
182
16
Posted in OutsideCamping
Introduction: Make a Portable Camping Shower
About: I like making food and trying food!
In this Instructable learn how to make a portable camping shower. What sets this apart from a regular shower is it's pressurized so no need for a gravity feed bag that you hang from a tree, make this shower truly portable. This shower is super useful and is great for washing off after a day at the beach or after surfing. Or it can be used to water plants, especially useful if you have a rain barrel and need a way to get water to your plants.
Step 1: Check Out the Video
Check out the video for the whole process the written instructions are in the following steps.
Step 2: Parts
The parts for this shower are very easy to obtain and you should be able to find them at the local hardware store.
You will need:
  • Garden sprayer or deck sprayer (use a new one or one has not been used to spray chemicals)
  • Garden hose barbed adapter
  • Garden hose nozzle
  • Small hose clamp
Step 3: Assembly
  • Remove the spraying wand or nozzle from the garden sprayer.
  • Save the wand in case you want to convert it back.
  • Screw the barbed garden hose adapter into the garden hose nozzle.
  • Put the hose clamp on the hose.
  • Fit the barbed end of the garden hose adapter into the hose.
  • Tighten the hose clamp.
Step 4: Operation
Pump up the garden sprayer to pressure the system. You are now ready to start showering!
  • Woodworking Contest
    Woodworking Contest
  • Outdoor Fitness Challenge
  • Casting Contest
    Casting Contest
16 Comments
What size barbed garden hose adapter is used?
How long does the water pressure last? Looks like you'd be pumping every minute or so.
When you use something like this to shower, it's not the same as at home. Get wet, soap, rinse. Minimal! I'm looking into making something like this for an Airstream trailer.
great insight manythxs
Thank you for this one, I will definitely be making one.
You can try painting It black and leaving It under the sun a bit for free heated water
Great instruction :-) I'd suggest to paint the container black in order to heat the water in the sun. That works for the gravity fed showers and should work here as well.
I will build one and let you share my experience.
I love this hack ! I have a bad back which makes hanging a bag overhead painful . I have a backpack sprayer that I haven't used yet. That would be perfect
Thanks this looks like it may be a bit expensive but better than putting loonies into the meter and then only getting seconds or no showering time which is what happened at my last camp site.
Great hack for a portable shower - much better than starting a siphon or placing a gravity-fed shower high-up.
I did a similar thing a few years ago, but instead of a shower, it was connected to my bidet that I installed onto my toilet. Room temperature water is more comfortable than the cold water from the pipes.
Simple and very resourceful. I was looking for a camping shower but I'd rather build this.
would it be possible to rig a heating element to it with a few 6v lantern Batts so the water is heated?
Just make sure you get a new sprayer from the store, a used one may have chemical residue that you don't want next to your skin.
