Step 3Disassembly and Frame Attachment.
Now it is time to begin assembling and aligning the frames.
On the bottom bike, if you haven't installed the front hub into the stem clamp, do so. Make sure it is centered left to right and clamp it down as hard as you like. Tighten the stem expander bolt so it is secure to the fork.
With the bottom frame standing up, resting on the fork ends and the bottom bracket (the fat tube that the cranks went through), lift the frame that will go on top up above it. Bring the upper frame down with the works and slide them onto the axle of the stem hub. Tighten down the axle nuts. Now your bikes are connected on the front end! Hold them up one on top of the other. I figure this is at least as strong as a decent weld job up here. The axle is probably the weekest link. This clamping system is also a little more forgiving of misalignment than a weld.
Add Comment
