Step 7Dis-assembly for Transport!
STEP 1. Loosen either the clamp that holds the hub in the stem... OR Loosen the axle nuts so the fork can slide up out.
2: Loosen up the seatpost clamp. If the bike has a separate clamp (not welded to the frame), make sure it doesn't fall off or that you don't lose it! Some of the separate ones have a little set-screw that hold it onto the frame.
3. Undo the chain around the upper crank. Now the top bike should be totally separated.
For the pictured bike, I simply stuck the two frames next to each other so they took up a minimum of height. I wrapped a couple bungee cords around them. In this manner you can make your tallbike fit into the back seat of a 1995 Honda Accord.
Add Comment
