3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Predator Shoulder Canon
Having completed the Bio helmet, it was time to start work on some other props for the body painting. I wanted to make the shoulder plasma canon, so I started with a Pepakura PDO file I found on the net.
I spent an evening cutting and assembling the Pep, but I soon abandoned it. It was HUGE and didn't seem in proportion either. I reasoned that once covered in resin and filler it would be too big and not the correct shape.
So I needed to build one from scratch.
Step 1Basic construction
Basic construction
The weapon essentially consists of two cylinders at right angles to each other. I used two sections of pipe lagging sponge and cut one for the barrel and one for the generator. The exact dimensions were not that important since it seems from the films that each predator has their own personalised canon.
I cut one section about 10" (26 cms) long from 1 1/2" (38 mm) diameter lagging and one section 2" long from some 2 1/2" (65 mm) lagging. I carved a curve in one end of the smaller diameter to mate up the the larger using a sharp knife, then using cocktail sticks to strengthen the joint I glued them together. This gives the basic general shape and already looked better proportioned than the PEP.
I then added a flat section, a piece of a barrel and then gave the entire thing a coat of resin. Once cured I filled some of the gaps and sanded it back. This leaves a thin hard shell over a lightweight foam core.
7 comments
Jun 11, 2011. 10:51 PMWolfy predator says:
B <5=O 70A;C65==0O 5!
Nov 10, 2011. 11:54 AMjalvarado-3 says:
Agreed
Jul 31, 2011. 8:52 PMaidanjarosgrilli says:
i will by it off you
Aug 1, 2011. 5:43 PMaidanjarosgrilli says:
what is it in australian dollars?
Feb 4, 2011. 9:54 AMtchitwood says:
Wow! That is awesome! So detailed. Wonderful job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
244
Author:marshon(Marshon)
Untidy, disorganised and a bit silly. I am a photographer, artist, body artist, sculptor, prosthetic maker, model engineer, and general idiot who likes making stuff and messing about.
