This is how I made a waterproof case for my digital camera. It's not a super detailed instructable...more like a build-a-long. It's full of great ideas on how you can make your own...
One great hurdle this case solves is the camera interface. Mose DIY waterproof (hard) cases don't have a way of operating the camera's shutter. It's usually just turning on the camera and sticking it inside a box while it films.
My lake is frozen, so I'll need to wait until it thaws to get some good pics. I'm stuck with the sink for now!
Remove these ads by
Signing UpStep 1The Box I used...
But anyway nice Ible.
Oh and a bonus to the bag is you can actually mess with your setting through the bag.
this would be useful if you have a camera like mine:
www.elitezoom.com/wp-content/uploads/2008/07/fujifilm-s1000fd.jpg
it's technically a digital camera, but it's still not a DSLR.
Have a fun time trying to find a case for THAT, and if you do, I'll be surprised, but my point still stands that this is a cheaper alternative :)
(in case the link doesn't work; it's a fujifilm finepix s1000fd)
But you are right...in this case its cheaper to go the crafty route as they Dslr bags are $30-$120. However you will have slightly better control over your camera thru the bag. I personally wouldnt trust a DSLR in one of these. Stick to cheapo $200 cameras for your snorkeling.
It would be pretty cool if you added a hole for the flash so you could take pictures underneath the water when is dark.
where did you get the black sticky foam?
thanks for sharing
It's a hard thing to find in the store, so you should ask an employee for 'sticky-backed foam'.
It comes it tones of colors...real cheap, too.
I'll test it to it's limit (until it springs a leak), and then post my results here.
Good luck!
The tests you did are doubtful. You test the device in some 10-15 cm of water and not in real conditions. If you aim to use it in lake waters the only issue you have to take care is the pressure. 1 m under the water is scary enough.
For the salty water please don't try it . Salt is very annoying thing. Penetrates easy and the damage is done before do something else. You have many holes, so may points of water entrance. You have to do something about it. Also the pressure in salty water is more bigger. Recently i found in stores a waterproof case that fits to any camera (mean compact camera) and costs about 40 euros.
Nice try anyaway
You will have fewer holes in the housing ( = less points of entry for water = fewer failure possibilities), and since water pressure will always be pushing in on the plexiglass plates (remember to seal the plates on the outside of the box!), nothing will threaten the glue seal.
Bolts would only be needed if there was a chance that the plexiglass would get shear forces, like from a glancing blow to its edge, but that's not really a problem for this application.
