Looking for a fast, inexpensive recycled project that you will love wearing or giving as a gift?
TRY MAKING PAPER RECYCLED BEADS!
Turn junk mail,magazines, brochures, last year's calendars, and gift wrapping paper into cool beads that may be used for bracelets or necklaces.
Before taking that stack of old magazines to the recycle bin, tear out a few pages with your favorite colors...with a few quick cuts, one magazine page yields enough beads for 3 bracelets! You can wear your finished product in about 1 hour!
Everyone asks me about the cool painted, wooden beads in my bracelets...yes, those are the PAPER BEADS made from RECYCLED Pages from MAGAZINES AND BROCHURES!
Try making some recycled paper beads today...I think you will be amazed!
Step 1: SUPPLY LIST~
For one recycled paper, glass and silver bead bracelet (similar to the two pictured below), you will need:
-1 page from an old magazine, junk mail, calendar, brochure or a piece of gift wrapping paper- suggest choosing a colors you enjoy and one with a glossy finish. Don't worry about words on the page!
-A paper cutter with marked measurements or an utility/ exacto knife and ruler
-A glue stick
-Wooden toothpicks
-Clear nail polish and a small piece of styrofoam (optional, see Step 4)
-Elastic beading cord (about 9-10")
-Leftover silver and glass beads
-Cuticle scissors
Step 2: CUT THE MAGAZINE PAGE INTO STRIPS
-Tear or cut the page from the magazine (calendar, brochure, wrapping paper, etc.) that you have selected.
-Using a paper cutter (pictured) or an utility knife, begin cutting the page into strips. Starting at either the bottom or the top of the page, cut the page into 1/2" strips. (The strips I typically use are approx. 1/2" by ~7-8" long.) You may cut the entire page into strips or cut at least four for the bracelet.
-Next, cut each strip in half on the diagonal. To make one mixed bead bracelet, I typically use 8 diagnonally cut "triangle" shaped pieces of paper.
'(Pictured is a page from a resort marketing brochure- there is one 1/2" cut strip and one strip that has been cut in half diagonally.)
Step 3: ROLL AND GLUE
-Organize a work space with the 8 diagonal paper strips, several toothpicks, a glue stick and some clear nail polish.
-Take a toothpick and one paper strip. Roll the WIDE end of the paper strip completely around the toothpick ONE rotation. Next, take the glue stick and quickly cover the remaining paper surface with glue. I usually quickly run the glue stick over the paper twice. You may need to wipe any excess glue from your hands if they get too sticky!
-Now it is time to completely and TIGHTLY roll the paper stip around the toothpick. Smooth the tip/end of the paper strip in place. Next, slip the paper "BEAD" off the toothpick. It should slide off easily since 'the glue was not applied to the section of the paper that directly touches the toothpick.
Note: This opening made by the toothpick will provide the space to string your beads onto the bracelet cord.
Just make a little stack of completed beads...the glue will set up while you coil the remaining paper beads.
See the two additional photos below.
Step 4: SEAL THE PAPER BEADS
This step is optional...
I prefer to add a gloss coating to the beads. It seems to harden/ cure the paper and helps the bead to be more water-resistant (ex. if water splashes onto the bracelet when washing your hands---would not recommend wearing the bracelet while bathing---even if you do seal with the nail polish!) You decide if you want to include this step...
-Select a finished/glued bead. Place upon a toothpick and "polish" with the clear nail polish. The polish I use dries in less than 5 minutes. I stick a row of the toothpicks containing the polished beads in a piece of styrofoam so they may dry without touching the table top or each other.
-After the beads are dry, inspect each one and use the cuticle scissors to trim away any tiny paper tags that are not completely glued/ sealed in place.
Step 5: STRING THE BEADS
-Organize your beads into a "stringing" order. I usally use 8 recycled paper beads mix in a few leftover silver and glass beads for color and variety.
-Cut the beading cord in a 9-10" piece. I like to triple knot the cord- so I add in a little extra cord to make sure there is enough to tie and then trim the excess. If you are making a bracelet for a child or smaller wrist, adjust the size accordingly.
-String the beads, knot and trim the excess cord.
Step 6: ENJOY YOUR RECYCLED PAPER BEAD BRACELET!
You did it! Enjoy wearing your bracelet....
The two bracelets below were made using paper from this calcium brochure!
1-40 of 88Next »
A_lil_birdy says: Feb 23, 2013. 3:25 AM
Great idea, I forgot to take off my bracelet after washing up the dishes and now the beads are a little worn out but I can renew them! I'll post a picture of mine soon..It's great for sleepovers..I'm not eighteen really...I don't wish I was either.
ladolph says: Jun 4, 2012. 10:29 AM
Hey, I actually found this on StumbleUpon last night and since then have gone bead crazy! I am an avid crocheter/knitter/etc, but don't generally do these kinds of crafts. I have been dying to try something with beading and am also obsessed with re purposing so your project was the perfect thing!
Thank you for sharing and for the wonderful pictures and instructions - you made it a breeze, and I can't believe how easy it was! Thanks again! :)
Anita Green says: Apr 18, 2012. 9:52 AM
How does one make a round shape bead from paper?
Anita
realmassage says: Jan 30, 2012. 11:50 PM
I have a question.
Initially, I found this tutorial under the 'Green Jewelry' heading. To make this a truly green project, what sort of adherent (glue) can be used? Also, what sort of 'green' sealant?
It's a great idea, and I truly love it, but would like to know how to make it actually 'Eco-friendly'.
Thank you.
Shadow_Force says: Sep 29, 2009. 2:30 PM
This is nice!!! It's so fun to make the beads, and the resulting colors are amazing! Here's a pic of a bracelet I made with the beads.
AlwaysAllTheTimeCrafting (author) in reply to Shadow_ForceJan 27, 2012. 1:35 PM
Love It!
AnitaCHawk in reply to Shadow_ForceDec 17, 2011. 7:11 AM
Wow, your's look really good. I'd never thought of making beads going horizontally. At least I didn't think it would look nice. The glaze you used seems good. Did you use any and what kind?
pamboni in reply to Shadow_ForceSep 6, 2011. 11:54 AM
How did you put this beautiful bracelet together? Do you use elastic?
AlwaysAllTheTimeCrafting (author) in reply to pamboniSep 13, 2011. 5:30 PM
See Step 5 in the directions above...you can see a picture of the elastic cord I used. It's sold in the beading section of craft stores and maybe even Wal-Mart or JoAnns. I've used it with success on many jewelry projects. Good luck.
pamboni in reply to AlwaysAllTheTimeCraftingSep 14, 2011. 7:32 AM
Thanks so much for your quick reply. I'm on my way to Michael's today and will buy a roll of elastic. Your bracelets are beautiful. Have any good ideas for necklaces with paper beads or earrings?
htonks in reply to Shadow_ForceJul 6, 2011. 12:31 PM
How dod you get the long beads so perfectly shaped? Mine all fall apart and look horrible.
AlwaysAllTheTimeCrafting (author) in reply to Shadow_ForceSep 29, 2009. 3:11 PM
Fabulous! Love your bracelet design...thanks for including the picture!
zani87 says: Jan 27, 2012. 12:07 PM
Hello!
First, thanks for this instructable, because it made me remember that I already tried this techniqe when I was a child :) So I decided to make again some nice colourful beads, and here's the result:
AlwaysAllTheTimeCrafting (author) in reply to zani87Jan 27, 2012. 1:34 PM
Wow! Looks GREAT!
rpackham says: Jan 13, 2012. 10:06 AM
Hi, I abosolutely love this craft! We did it forever ago in 4th grade, I think. We used cornstarch, but I've found this to be soo much easier! Thanks a ton!!(:
platinum15 says: May 16, 2010. 11:47 AM
 LOVE THIS!!!! dyu think that it would b 2 hard 2 teach k-5 grdrs how 2 make this??? im volunteering @ a summer camp and i hav 2 teach them how 2 make stuff >.<
rhigbee in reply to platinum15Nov 30, 2011. 1:01 PM
I taught my 6 yr. Grandson in less than 5 mins. And he loving it!
AlwaysAllTheTimeCrafting (author) in reply to platinum15May 16, 2010. 1:47 PM
Hi- I think it may get frustrating unless you have lots of older helpers-  probably better for middle school age groups.
Have you considered dyeing dry pasta with food coloring and rubbing alcohol?  The alcohol evaporates....the younger kids would enjoy sorting pasta shapes/ colors and making necklaces using yarn....try googling it to get the right food coloring/ alcohol ratio.  Used to make this frequently when my girls were in preschool/ elem. school...they loved it!
platinum15 in reply to AlwaysAllTheTimeCraftingMay 16, 2010. 2:39 PM
 oh cool!!!! thnx!!!!
rhigbee says: Nov 30, 2011. 12:49 PM
Different instructions say not to use watercolor markers. I love using them. I makes the beads look marble like. I just started making beads a month ago and I am having the best time!
tammydey says: Oct 20, 2011. 6:18 AM
These are fantastic! I shared your tutorial at aimeeasher.com
Can't wait to try some!
AlwaysAllTheTimeCrafting (author) in reply to tammydeyOct 20, 2011. 10:22 AM
Many thanks :)
bsmith-58 says: Sep 13, 2011. 3:32 PM
love making the beads but would like to make some short fat one to go between the long ones. could u please help. I've several pair of earrings for relatives.
AlwaysAllTheTimeCrafting (author) in reply to bsmith-58Sep 13, 2011. 5:28 PM
Glad the project has worked out for you. In terms of ideas- maybe you could use a narrow strip of paper that is longer---think that should give you a "fatter" bead.
If you have any old beaded earrings or leftover beads from other projects, you could use one glass/metal bead and one paper bead. That's what I did in the pictured bracelets. Good luck with your project!
bsmith-58 in reply to AlwaysAllTheTimeCraftingOct 19, 2011. 5:12 PM
Thanks for your respond. I will give this a try.
Mauigerbil says: Jul 31, 2011. 12:50 PM
Cool!
htonks says: Jul 21, 2011. 9:42 PM
I have mastered the subtle art of this craft- and kind of defeated the 'recycled' part xD
I went to craft store and bought scrapbook paper- beatiful colors and designs of my choosing :D i still use magazine, but this paper is sturdier and rips and crumples less
Mzuribeads says: May 15, 2010. 3:04 AM
We hope you don’t mind us leaving a note to tell you about our fabulous Ugandan Recycled Paper Mzuribeads, Barkcloth, Banana leaf, and recycled Glass beads ON SALE at http://www.mzuribeads.com/
Here you can check out a selection of ethical and eco beads all made by groups building sustainable businesses and promoting environmental awareness.
Thank you for your support, and for promoting sustainable bead projects.
Mzuribeads
the.bead.rolls.on in reply to MzuribeadsMay 5, 2011. 8:45 AM
I welcome you presence at THEBEADROLLSON Facebook Page!
JONIEK says: May 18, 2010. 12:45 PM
HOW DO YOU GET THE BEADS TO COME OUT SO UNIFORM?  MINE ARE NOT VERY EVEN. IS IT THE WAY I CUT THEM?
the.bead.rolls.on in reply to JONIEKMay 5, 2011. 8:44 AM
can you send a picture of them to THEBEADROLLSON page on Facebook?
AlwaysAllTheTimeCrafting (author) in reply to JONIEKMay 18, 2010. 1:55 PM
I did measure mine pretty carefully...also, in the picture, you are seeing the best of the ones I made.  The first ones were not rolled as uniformly... practice does make a difference- at least for me!
the.bead.rolls.on says: Mar 8, 2011. 3:53 PM
Here is a video about it www.thebeadrollson.com! Love it!
the.bead.rolls.on in reply to the.bead.rolls.onMay 5, 2011. 8:43 AM
If you want to join the facebook page TheBEADROLLSON, i can answer question and exhibit your work!
rudegirl says: Dec 28, 2010. 12:51 AM
love the idea tried it and it works great also regular uhu glue works just fine
Fanny Fink says: Dec 26, 2010. 2:02 PM
thank you. they look nice.
zyx456 says: Dec 8, 2010. 7:48 AM
Can you adjust the measurements to create bigger beads
crazyaboutbeads says: Sep 30, 2010. 11:02 AM
This is SO beautiful! Do you use filler beads in between?
jumpertoad says: Oct 10, 2009. 1:09 PM
I cant cut correctly
crazyaboutbeads in reply to jumpertoadSep 28, 2010. 12:55 PM
Try using a ruler to steady the knife. That way it is more steady.
1-40 of 88Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
