Make a Rainy Day Tissue Box Guitar! - Great for Kids
 by Weissensteinburg
I'm going to show you how to make a guitar with your kids out of a tissue box, paper towel roll and some rubber bands! My mom and I used to make these all the time when I was little - They're really fun!
Step 1: Tools & Supplies
The stuff that you need is pretty simple...
Empty tissue box (the long kind)
Empty Paper Towel Roll
3 Rubber bands (You may want another in case one snaps)
Tape
Something to cut with
Marker
A kid ready to have fun! (The inner kid in you works too :D)
Step 3: Cut hole for the neck
Now you're going to be making a hole in the box for the neck/paper towel roll. Go to one of the small sides of he box, and put your paper towel roll on top. Use your marker to trace around the roll, and then cut out the circle.
Step 5: Add the strings
Now you can add the strings, just put a rubber band around the box, one on each side of the neck. You can also put one straight in the middle by cutting halfway through the neck right at the base, sliding a rubber band into the slit, and taping over the where you cut. (You can go ahead and play it now)
Step 6: Extra Things to Do
Here are a few extra things you can do to make your guitar even better!
1. Add bridges (suggested by lemonie)
2. Make different tones using different types of rubber bands (suggested by lemonie)
3. Add space for strumming
Adding Bridges
Bridges raise the strings of a guitar off the base, allowing the strings to vibrate freely in the air, producing better notes.
What you need:
2 index cards
tape
1. Fold up the index cards so that they are a little less than a cm wide.
2. Place under strings at the very top, and bottom, of the base of the guitar. Then tape to the box on the sides, where the tape won't interfere with the strings.
Different Notes
Using different size and thickness of rubber bands will change the notes they produce when plucked.
What you need:
Different rubber bands!
1. Just replace the old strings with new ones
More Strumming Space
If you're like me, the strings would sometimes hit the box as you played, this is how I solved it.
What you need:
Your cutting device from before
1. Figure out which way you hold the guitar, and then determine which side faces down as you play.
2. Cut out as much space as you need from the bottom of the hole. (when you're holding it, NOT the thin side) I needed about a centimeter.
Step 7: Decorate!
Use whatever you want to make your guitar prettier! Stickers, crayons, paint, whatever you have!...You're done! Now you can go and start a rock n' roll band!
Gage987 says: Mar 10, 2010. 2:02 PM
wrapping paper tubes they are long enough to go all the way through and still stick out.
jakee117 says: Jun 3, 2008. 1:35 PM
heh I saw this on blues clues when I was like 6 but it is still so AWESOME!!!!
X_D_3_M_1 says: Oct 26, 2007. 9:34 PM
these osudned wierd. made em when i waas 6
Danny says: Sep 11, 2007. 8:11 AM
ha the irony rainy day you say?
Weissensteinburg (author) in reply to DannySep 11, 2007. 11:52 AM
Where's the irony?
Danny in reply to WeissensteinburgSep 12, 2007. 12:57 PM
its blazing sunshine outside
Weissensteinburg (author) in reply to DannySep 12, 2007. 12:59 PM
ohhhh..but now I can play while it's raining.
kiwi_soccer_maniac says: Apr 15, 2007. 2:49 AM
i remember making this at primary good times
Always Dance says: Mar 11, 2007. 10:17 AM
I love your project; the stickers add a nice touch, too!
Weissensteinburg (author) in reply to Always DanceMar 11, 2007. 11:07 AM
Thanks :D They're left from the most recent "Birthday Crown" my Mom has made. Maybe I should have an instructable on those too :P
evy-wevy says: Mar 10, 2007. 10:30 PM
is this entered in the popular science contest? It is the epitome of recycled, i'm sure you will do well...
Weissensteinburg (author) in reply to evy-wevyMar 10, 2007. 11:11 PM
Actually - It is - Thanks for noticing!
lemonie says: Mar 10, 2007. 1:02 PM
Yea!
Weissensteinburg (author) in reply to lemonieMar 10, 2007. 1:19 PM
Does that mean you like it? :D
lemonie in reply to WeissensteinburgMar 10, 2007. 4:54 PM
Yes, I do. I was thinking of bridges and differing gauges of rubber-bands, but I see how this could so easily keep kids (or adults) amused. Having hacksawed coconuts, this is something I really should have thought of. L
Weissensteinburg (author) in reply to lemonieMar 10, 2007. 5:30 PM
I think ill add both of those ideas to the instructable...tomorrow - Thanks. I had thought about the different types of rubber bands. but never thought of making a bridge.
Weissensteinburg (author) in reply to WeissensteinburgMar 10, 2007. 6:11 PM
Cancel that - I decided to do it now. I added another step showing your ideas and one of my own. I also added a sound clip in the intro of how it sounds.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
