Needed:
- Two conventional neckties of sufficient width, and almost the same width.
- Sewing machine, seam ripper, steam iron, fabric scissors, matching thread, pins, hand needle.
- Basic machine skills and sewing terminology.
The tie will be reversible, and suitable as a formal ascot, or for retro-fashion like Steam Punk or Victorian. But unlike a genuine cravat, the tail end will be half the width of the visible front. In most applications, this makes no difference.
I've only ever seen one ascot tie in person. This project is patterned after that piece. The ascot is worn formally around the collar for "morning dress" (see Wikipedia), but was also worn inside the collar as casual wear for upper-class Yachtsmen and for other sports like golf. You'll see this in sit-coms of the 60's like Gilligan's Island.
Because conventional neckties are cut on the bias (diagonally from the yardage) you will notice when working that they tend to stretch in their length. Silk cut in rectangles would not behave this way.
Remove these ads by
Signing UpStep 1Choosing neck ties to re-purpose
Notice that a necktie is roughly twice as wide when you open up the back. Bonus! For traditional formal wear, the pattern should be gray stripe or textured silk, not printed. The colors of the two ties need not be related because only one side will show at a time. The pieces should be stain-free and snag-free on the wide end.
Then gently pull the string when you are ready to turn it inside out. Once it is right side out, cut the thread and shake the bead out. No damage to the seam or fabric. :)
What this needs is a steampunk tie pin to really finish it off: http://industrialradical.com/category/shop/jewellery/tie-pins/
Good work!
And a second tie.
Will this look - including nose bone - end up as acceptable or unacceptable on Royal Ascot's website. We can hope :-)
http://www.ascot.co.uk/royal/dress_acceptable.html
