Make a Robot With Arduino for Beginners
Published
Introduction: Make a Robot With Arduino for Beginners
Step 1: Materials Needed
  1. Tamiya Track and Wheel Set Assembly ($7.95 at Pololu)
  2. Tamiya 70168 Double Gearbox Kit ($9.25 at Pololu)
  3. L298N Dual H Bridge ($3.65 at Amazon and might be much lower at ebay)
  4. 4AA Battery Holder (used from broken electronics)
  5. 200mm Female and Male Jumper Cables ($2.60 at Amazon)
  6. Universal Tamiya plate ($7.77 at Amazon)
  7. Arduino Uno or its clone
Note: Universal Tamiya Plate is optional. That is you can use wood in place of it. But, for convince I've used the plate.
Step 2: Procedure
  1. Assemble the gear motor as described in the manual. For this project I've used 114.7:1 gear ratio
  2. Mount the double gear motor onto the Tamiya plate
  3. Connect the 6V battery holder (+) to the L298N +12V port and (-) to the GND using jumper cables
  4. Connect the arduino GND to the L298N GND
  5. Finally, connect the motors to the L298N two side output ports
  6. Follow my drawing for circuitry for further clarity
  7. Connect the pins of L298N to Arduino as the following:
Right side
Pin1 --------------------------------- 3 of Arduino (PMW pin)
Pin 2 --------------------------------- 6
Pin 3 --------------------------------- 4
Pin 4 --------------------------------- 13
Pin 5 --------------------------------- 12
Pin 6----------------------------------- 9 (PMW pin)
Note: Don't worry about the polarity of the motor connection because we can change it through the code
Step 3: Code
First of all, download the Arduino Software from their website. Then copy and paste the following code:
void setup(){
 Serial.begin(9600);
 //right motor
 pinMode(3,OUTPUT);
 pinMode(6,OUTPUT);
 pinMode(4,OUTPUT);//pwm
 //left motor
 pinMode(13,OUTPUT);
 pinMode(12,OUTPUT);
 pinMode(9,OUTPUT);//pwm
void loop()
  int Racerspeed=80;
  int ReverseSpeed=60;
  //forward
 digitalWrite(6,HIGH);
 delay(100);
 digitalWrite(4,LOW);
 analogWrite(3,Racerspeed);//right motor</p><p> digitalWrite(13,HIGH);
 delay(100);
 digitalWrite(12,LOW);
 analogWrite(9,Racerspeed);// left motor
 delay(4000);
 //reverse
 digitalWrite(6,LOW);
 delay(100);
 digitalWrite(4,HIGH);
 analogWrite(3,ReverseSpeed);</p><p> digitalWrite(13,LOW);
 delay(100);
 digitalWrite(12,HIGH);
 analogWrite(9,ReverseSpeed);// left motor</p><p> delay(5000);</p><p> //stop
 delay(100);
 analogWrite(3,0);// right motor</p><p> digitalWrite(13,LOW);
 delay(100);
 analogWrite(9,0);// left motor</p><p> delay(5000);
 //turnleft
 digitalWrite(13,LOW); //changed this (7/12/2015)
 delay(100);
 analogWrite(9,30);// left motor</p><p> digitalWrite(6,HIGH);
 delay(100);
 analogWrite(3,120);//right motor</p><p>  delay(1000);
Step 4: Future Updates
Yes! You saw it right there are more updates coming for this robot. Some of them are as follows:
1) Adding ON/OFF switch
2) Controlling it with IR remote
3) Adding distance sensor
Stay tuned, and happy making robots!
Any donations will be used for future projects, thank you!
Donate
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    9 Comments
    Love this! Thanks for posting. I have a couple of questions. First, are you running the arduino and the motor controller off of the same set of batteries? Second, how did you connect the tiny Tamiya motor connections to the motor controller? I was hoping for a solderless connector but can't seem to find any that fit.
    Yes, I'm running arduino and motor controller with same set of batteries. I soldered them to a wire. This is the most convenient way to connect them.
    what is gnd?
    Ground, connect that to the negative terminal of the battery
    You are welcome!
    Can we get all the parts and set in india??
    Yes I think so, but maybe with different name. You need to some research.
