You will need the following items to make the rotating microphone work using my methods:
1 Electret Condenser Element (for this application a unidirectional capsule will work best)
1 Male XLR Connector
1 Female XLR Connector
1 Male 1/4" TRS --> Male XLR adaptor
1 Female 1/4" TRS plug
1 DC Motor (9V) with gear
1 Circular lightweight piece of wood (I got mine at Hobby Lobby)
1 Drill
1 Rubber Gear Strips (long enough to cover the circumference of the wooden circle; matched to motor gear)
1 Glue (Gorilla Glue or something like it)
1 Wood Glue (used for the rubber gear strips and the wooden circle)
1 H Bridge
1 10k resistor
1 2k resistor
1 1000pF capacitor
2 10uF capacitor
1 Analog or digital switch
1 Potentiometer (50k-100k will work)
1 Arduino microcontroller (I am using the Diecimila) including a computer or other way to program the board. You do not need a computer to use the rotating microphone once the Diecimila is programmed and has 9V of power coming in (center positive).
1 9V power adaptor (center positive, not exceeding 300mA)
1 9V battery or 4 AA batteries in a 4 AA Battery Cell Holder
1 breadboard for motor circuit
1 perf board for the mic powering circuit
A good bit of wire and alligator clips
small plastic clamps
electrical tape
Soldering iron with solder
small lightweight plastic bottle with screw on cap (I used a small bottle of Dr. Bronner's Magic Soap)
large plastic bottle cap (to hold the motor in place)
mic stand
small mic clip
optional:
rubber mount for electret capsule (I used one that I stripped out of an Apple PlainTalk microphone)
Remove these ads by
Signing UpStep 1: Make the microphone powering circuit
http://www.prosoundweb.com/recording/tapeop/buildmic/buildmic_16_1.shtml
You can also power the microphone using four AA batteries in a four AA battery cell holder.
I chose to make mine with XLR in/out as XLR is usually the type of mic inputs that I'm using.
I went ahead and made the circuit on a perf board- it's much easier to do on a perf board that has some connecting strips for ground, etc.
The microphone circuit that is also shown on the web page will be used later on so bookmark the page for future reference.
Visit Our Store »
Go Pro Today »
online mastering
There are now some really interesting surround sound and ambisonic microphone options that allow you to do just what you are describing by decoding a 4 channel Soundfield B format microphone signal.
Soundfield- http://www.soundfield.com/soundfield/soundfield.php
Also, check out this more affordable option from core sound:
http://www.core-sound.com/TetraMic/1.php
In order to simulate turning your head, with a neck that can rotate 360 degrees (!) you could utilize two microphones in a stereo configuration and rotate both of them at the same time.
I was also thinking about simulation of 3D spaces using a rotating sensor, it wouldn't have to be a mic necessarily. An ultrasonic range finder would perhaps work better. With the ultrasonic range finder you could send out a ping and measure the delay of the acoustic reflections in a 360 degree X Y planes, then do another rotation in the Z plane. With the combined data you could figure out the dimensions of the space and possibly start to come up with representations of the objects that inhabit that space.
It looks like it wouldn't have the frequency modulation (doppler shift) vibrato of a rotating speaker, because the sound source isn't moving.
gmoon's suggestion of moving the mic to the outer rim may add the doppler shift. To sound more like a Leslie, two microphones may be used, set on opposite sides of the turntable. Then one is moving closer, while the other is moving away (like the Leslie horn).
Does adding a horn to guide the sound to the microphone change the sound much?
I find most cheap electret condenser capsule microphones from toys are fairly omnidirectional, so a horn may improve the effect.
Wikipedia: Leslie Speaker
The baffles on the good leslies are simply light plywood (styrofoam just doesn't hold up as well). and played loud enough to cancel most motor noise.
http://www.m0gdu.co.uk/leslie.jpg
This particular model combines both methods - there are a pair of treble horns that physically rotate at the top, and a larger bass speaker that faces downwards into a rotating drum baffle... if you look at the right hand side of the drum you can see the edge of the cut away portion.
What you can't see is that there's a small weight attached level with the cutaway to replace the missing mass so the whole assembly is balanced correctly - if you forget that the whole machine tries to walk across the floor!
For anybody who is interested, I've uploaded some music here
http://www.m0gdu.co.uk/homemade.zip
It's a zipfile of around 37Mb and contains MP3s of several popular tunes played by myself.
http://www.m0gdu.co.uk/soul_limbo.zip
is a smaller download (under 3Mb) because it's a single track.
It features the use of a Leslie speaker on the organ - when you hear it you'll recognise it instantly... that 'swirling' sound is it.
