3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Server Out Of An Old PC
Using an old Dell XPS, abandoned in my step-mom's office, I made a local server to host files for public worldwide access.
All you need is an old PC, high-speed internet, a router or switch for multiple computers, and PATIENCE.
Images WILL BE UPDATED LATER!!!
Step 1Get the computer!
Get the computer!
First of all, you need an old, or maybe new, PC to convert to Linux. Look around your house, find a friend who will give one up, or search for one online or at a flea market or something. Something like the one pictured below.
I found mine in my step-mom's office.
68 comments
1-40 of 68next »
Dec 11, 2011. 8:21 PMdarthbindy says:
i got the same one, found it in the trash, iv been fixing it for a week now, and iv gotten it to the ubuntu boot screen were it asks if you want to try or install, but whenever i i select one then it just script screens........
Jan 5, 2012. 1:55 PMzutalors says:
The last version of Ubuntu is a dud for older PCs, due to the new GUI it tries to use. Same thing happened when I tried to install it. The latest version of Debian with Gnome GUI works very well on the same PC, even better than older versions of Ubuntu ever did. Try that or, if you really want it, a version of Ubuntu before Oct 2011.
Aug 24, 2010. 6:49 AMharry599 says:
whaen you have to insert your local ip, is that the computers ip or the routers ip, because i dont have a static ip on my router so how would i get by that? Thanks Harry
Oct 1, 2011. 10:18 AM______ says:
type in http://localhost/ to see your site.
Mar 12, 2011. 8:37 AMhpiper-inkpen says:
tar xvfz xampp-linux-1.6.3a.tar.gz -C /opt
it may be a typo and you did it right, but it's supposed to be:
tar -xvfz xampp-linux-1.6.3a.tar.gz -C /opt
Nov 21, 2010. 2:06 PMComputothought says:
So much has changed since this instructable was one. though you could still basically use it.
Jun 23, 2008. 6:19 PMLeonardodanguyen says:
um...I really bad at this so this might be a bad question but please answer me. Are we installing the Ubuntu Server Edition or the Ubuntu PC Edition?
Nov 22, 2009. 5:44 PMcornboy3 says:
 This really depends on your competence with unix and linux systems. If you have used ubuntu server before or you are master of the bash prompt then use ubuntu server. If you are somewhat new to ubuntu or are stumbling into the terminal for the first time then choose ubuntu desktop edition. As a side note, ubuntu server takes computational power to run because it only runs a bash prompt, no gui.
Jan 11, 2010. 7:22 AMskywagger says:
Just set it up with GUI then Turn it off, even a n00b can do that
Oct 26, 2009. 2:02 AMolegarza says:
Really good Question!!!
Jun 3, 2008. 10:22 AMDerin says:
will try this on an old compaq i bought from the ebay ps will 2.5 gb enough
Oct 3, 2009. 9:15 AMfallenspirit123 says:
it should
Jul 9, 2009. 12:53 PMComputothought says:
I have run a minimal web serrver on a 2 gig drive with debian.But it took some fine tuning to do it. You can get a compact flash to ide adapter and compact flash pretty cheap now..You could also use the 2 gig drive as a boot drive ( if you can not usb boot) and connect a usb drive for extra storage. Usb drives are dirt cheap also compared to what they used to be. Some but not all cheap thin clients can easily be. be made into servers. Even some nas's can used be also. I used my nslu2 as a debian based web file server for a long time. .Freenas software is a another good starting point for older equpment..
May 25, 2009. 11:09 PMmage says:
4GB storage is the minimum for Ubuntu unless you meant ram in which in that case you have more then enough
Nov 21, 2010. 1:47 PMComputothought says:
I have used debian with as little as 100 megs of ram and a 10 gig hard drive as a web server with room to spare.
Sep 28, 2009. 1:56 PMmattronix says:
hi i need help not tech i can install this on mattronix server2 but................ im crap with text interface i need GUI HELP!!!!
Aug 29, 2009. 11:50 AMreederda says:
What do you do if the computer won't install ubuntu?
Jan 10, 2008. 2:18 PMComputothought says:
(removed by author or community request)
Jul 8, 2009. 2:19 PMpower Bills says:
or you can Just download to a flash if you know what a USB port is in the back of most CPU I seen
Jul 9, 2009. 12:42 PMComputothought says:
true if the machine is new enough to support usb. The latest version of debian no longer supports the floppy boot, but you can i9nstall the old version and then upgrade for free. I have done that on some old machines.
Dec 2, 2008. 8:47 AMdjr6789 says:
please tell me what is thew point of this?
May 25, 2009. 11:06 PMmage says:
for teh lulz
May 25, 2009. 11:05 PMmage says:
would this werk on a laptop?
Mar 14, 2009. 5:41 PMN1CK4ND0 says:
This is EXACTLY what I'm doing!!! Ubuntu is coming in the mail and I'm gonna be hosting files so me and my clan can transfer information fast.
Jul 31, 2007. 8:08 AMjoejoerowley says:
I like it. Great instructable!
Feb 19, 2009. 10:08 PMA.O.C. says:
This is really interesting, i would like to learn more and possibly do it myself! Any other informational links so i could learn more....i am dumb when it come to comps but i really would like to learn more
Jul 31, 2007. 1:47 AMbleachworthy says:
I used to do this all the time, except I did it in a much simpler way. i just downloaded Apache webserver (to host web pages) and filezilla (for FTP transactions) build my site, set the permissions, changed my port fowarding settings in my router/modem, set up a free DNS resolution (a .TK name) and started spamming my link across the web, I eventually got a sponsor, and was making an extra hundred a month. Once I get up a hundred bucks or so, i plan to buy an old dell desktop with a P4, and a wireless card, and I'll be able to manage my whole site through a remote desktop connection, telnet, or SSH. it's an easy, fun way to earn an extra bit of cash, and learn computers while you're at it!
Aug 28, 2008. 5:43 PMAquilla says:
This sounds like the sort of thing that would make an excellent instructable, and I'd love to learn more about it.
Jul 18, 2008. 12:51 PMAlexizupinhea says:
Who's the sponsor?
Jun 18, 2008. 7:13 PMtheburn7 says:
wtf? my site name has been taken! http://www.theburn7.tk/
Jun 18, 2008. 7:12 PMtheburn7 says:
So is WWW.THEBURN8.TK www.theburn7s.tk WWW.THEBURN9.TK WWW.THEBURN.TK WWW.THABURN.TK all are crummy and stupid, and the list goes on
Apr 11, 2009. 11:05 PMKasm279 says:
parked sites
Jun 18, 2008. 7:14 PMtheburn7 says:
i guess i have to go with co.nr
Sep 18, 2008. 7:14 AMDerin says:
try .net
Jul 26, 2008. 5:39 PMREA says:
probably parked websites. reagames.com is taken :(
Mar 9, 2008. 8:24 PMschimmi says:
you just made me want to do that just for the extra cash, cause you can never get enough especially if you're 15 and without a job but from who did you get the domain name?
Jan 18, 2011. 8:59 AMtmccar says:
How do you earn cash from this (get a sponsor and all that) as per Bleachworthy?
Jul 13, 2008. 8:14 PMVitaminCM says:
This is a really cool article.
Here is an article on <a href="http://www.vitamincm.com/reusing-anreusing-an-old-pc-as-a-server/">Using an Old Computer as a Server</a> with Step-by-Step video instructions.
Jun 23, 2008. 9:01 PMbth8 says:
would knoppix be considered good enough
1-40 of 68next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Seski
I'm really just a kid, trying to learn things about electronics and computers. I'm already pretty good at programming and things. I maintain my own server on Ubuntu, and I'm a starting filmmaker, grap...
more »
