Make a Silver Cross Out of a Coin
Introduction: Make a Silver Cross Out of a Coin
A couple of years ago I made some small silver crosses for Easter for the family. I’ve done silver casting and soldering before, but wanted to do something a little more quick. I have a bunch of silver coin in a collection of coins I gathered during my days as a cashier years ago. People would come through the checkout line and somehow at the end of some nights I would have either a foreign coin or old silver.
U.S. coins, as well as many other countries’ coins, used to be made out of silver and not what we see today: combinations of nickel, copper, and aluminum.
So, seeing this bag of coins I’ve collected, I decided to try to make something out of them. I don’t cut up the Mercury dimes or Buffalo nickels, but I do use the quarters and nickels from the late 50′s and early 60′s. This is a project I wrote about on my blog, Sir Richard's Tool Kit.
These two crosses were textured with a propane torch.
Step 1: You Will Need...
The process is rather quick and doesn’t take many tools.
You’ll need:
a coin
wire cutters
small drill bit and drill
jeweler’s saw and block or a hack saw
small files
a hammer
maybe a pin vise
If you choose to partially melt the silver for texture, you will need a propane torch.
safety goggles- plase wear them. I've gotten metal and wood in my eye before and scratched my cornea. It is not fun. It will ruin your day.
Step 2: Marking
Start by making the shape of the cross on the coin with a pencil. The pencil wipes off easily with your finger, so you can mark it with a perminent marker or a scribe.
Step 3: Cutting
A jeweler’s saw has teeth that are very fine and cut soft metal. The wire cutters can maybe do all of the cutting on a thin coin like a dime. That’s a maybe. The amount of leverage required to cut the coin at the tip of the wire cutters can be difficult unless you have really good cutters with long handles. I don’t.
If you can do the cutting at the back of the cutters, it’s easier. That can be done a little later.
Using the saw and the block, which clamps to the table, cut out the shape of the cross. Using beeswax to lubricate the blade helps to prevent binding and breaking the blade.
If you don't have a jeweler's saw, a hack saw can do the work if you clamp the coin in a bench vise.
Step 4: More Shaping
Once the shape of the cross is cut out, clip the top and sides of it to make the cross proportional, othewise it’s an "X". Clip the ends with the wire cutters towards the back of the jaws like I mentioned before. Use caution because the little ends fly off and are sharp. The top piece i clipped is somewhere behind the couch.
It is possible to shape the cross entirely with a triangular file, if that’s all you have. It will take longer, but it can be done. I would recommend clamping the coin in a vise to do that.
Step 5: Drilling
Drill a small hole at the top of the cross to attach the cross to a necklace with a jump ring. You could wait until the very end to do this part.
Step 6: Hammering
Next, take a hammer to it an flatten out the markings on the coin. This can be done on any hard and flat piece of metal, like the anvil flat on the back of a bench vise. Or you can do it on a brick or a sidewalk. Remember, the texture of the surface you hammer on will transfer to the metal, for good or bad. Flip the cross over while hammering and use gentle taps. The silver is soft and does require the blows of a blacksmith.
On the crosses I originally did, I didn’t hammer them. I heated them with a propane torch and melted them enough to reflow the surfaces and create some nice texture. Try it, but be careful. It also allows you to pretty much skip the next step of filing and smoothing the edges. That’s what is called a fire polish.
Using some small files clean up the edges of the cross. You can also introduce some texture to the cross with gentle taps from a ballpeen hammer as well.
Step 7: Texturing
I decided it would be nice to add a stipple texture to it. This is easy to do on a soft metal like silver, copper, or brass. Any small drill bit can be ground to create a burin tip to make this texture with.
A 1/16″ drill bit has been ground on the back to a 45° angle with a Dremel bit.
I chucked the bit in a pin vise and did a final sharpening on a fine oil stone to remove burrs from the edge. That’s all there is to it. This makes a cutting edge that can be used to chip away a stipple texture. It takes a little practice, but it only takes a couple minutes to create a random pattern. If you really want to go cross-eyed, you can make a pattern that simulates a basket weave or linear pattern.
Step 8: Finished
Once you are done with with the texture, if you choose to do that, it's just a matter of adding a jump ring and stringing it up.
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    Isn't it a crime to deface federal currency?
    Yes, United States currency and coinage are governed by federal law through the U.S. Treasury Department. Generally, it is illegal to fraudulently deface, mutilate, impair, diminish, falsify, scales or lightens any coins minted or "coined" in the United States or any foreign coins which are by law made current or are in use or circulation as money within the U.S. (18 U.S.C. 331) It is also a crime to fraudulently possess, pass, publish, sell or attempt to possess, pass, publish, sell or bring into the U.S. any such coin with knowledge that the coin has been altered, mutilated, defaced, etc. (18 U.S.C. 331) Defacing currency with the intent to alter the bill to gain a benefit is illegal. If someone alters a written instrument (such as a check) without permission and with the intent to gain a benefit, then it is called forgery, which is a crime. If one tried to alter a cash bill (like changing a $5 bill to a $20 bill) for the purpose of presenting the altered bill to gain a benefit, then that could be considered a forgery. Forgery of United States Currency in this manner is called counterfeiting and carries with it very stiff penalties.
    It is legal to deface money if it is not going to be used as "money" when you are done with it its perfectly legal to make jewelry out of coins.
    Well, if that is the case then I think we shall be seeing a major crackdown on all of the penny smashing machines that are stationed at all the major theme parks, zoos, science centers, and tourist traps around the nation. I probably possess enough flattened pennies from the Woodland Park Zoo to have me put away for life. I'm flushing them down the toilet right now. i.e.- I don't think it's a big deal.
    Oh, don't do that. You'll have the EPA all over you for dumping possibly toxic elements into the environment. ;)
    It's illegal to attempt to make a fraudulent coin or to make a cheap coin worth more (try to make a nickel into a dime or quarter). You can however burn/melt down/ destroy your money if you so choose. You just can't attempt to spend it afterward.
    Awesome job! I've been wearing a cross made of nails and wire for a while, and it's becoming tarnished/corroded. I've gotta try this sometime!
    Using any kind of coin 1965 & earlier is not using commen since. Selling it & letting someone else enjoy it in there collection. Some coins can be worth $1,000.00's of dollars. Please check into pricing of the coin before u destroy it. Or use something besides a coin with silver content. Or better, just let me enjoy it in my collection.
    If ur going to destroy it.
    very good idea.... thanks for sharing
