Disclaimer: If following this guide anything damages i shall not be held responsible.Do it at your own risk.
Remove these ads by
Signing UpStep 1Components
1- LM 386 semiconductor (IC)
2- 100 micro Farad capacitor
3- 220 micro Farad capacitor
4- 10 ohm resistor
5- 5 kilo ohm variable resistor
6- 100 ohm variable resistor
7- 0.01 capacitor
8- 0.047 capacitor
9- Wires
10- 9V Battery clip
11- 9V Battery
12- 3.5mm stereo jack male
13- 3.5mm stereo jack female
14- Project board (or you can use dotted board and solder)
You can find these electrical components from your nearest electronics store.These all components are easy to find and are common so you won`t have a hard time to find it.
In my town I can find only LM386N..It will work?
I am trying to build something just like this for my class. My question is, what if I want to use a small 8 ohm 0.5 W speaker that has a red and black cable connected to it. Would I just replace the female 3.5 mm jack with this speaker?
You need to find a different circuit. Try searching for one using a Tripath Class T chip.
but it will give alot of noise & distortion so don't expect a high quality sound
Rather i will refer you a UPC 1288v IC according to your power supply
wat is actual function of amplifire??
plz rply
