3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Simple Audio Amplifier
Step 8Volume Controller
Volume Controller
7-Now again join the 5th pin of the IC with the +ve side of 220 micro farad, the -ve side of the pin should be attached with the A of the 100 ohm variable resistor.The B pin of the variable resistor should be connected to the GND pin (4th pin of IC).This becomes the Volume controller.
4 comments
Aug 19, 2009. 6:33 PMstupidkartik says:
does anyone know what voltage capacitors to install?
Feb 24, 2012. 1:35 PMRirishi says:
I'd choose 10v or higher. Just make sure it's higher than the 9v or it'll explode =D
Mar 3, 2010. 12:59 PMLogicdustbin says:
as I understand, it just needs to be larger then the supply voltage.
Oct 22, 2011. 11:15 AMprarthana says:
how to connect potentiometer ?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:zabi_rauf
