I needed to create an electromagnet for a project, so I decided to document the steps to show how to create your very own electromagnet.
Warning: The more current you place through the wire, the more heat it will give off and could start a fire if it becomes too hot. The wires will be hot after putting current through them. You can use thicker wires to allow more current. Recommended wire type is copper.
Materials:
1. Phone Line (or small insulated copper wires such as magnet wire)
2. Wire Stripper
3. Scissors
4. Pliers
5. D Batteries (power source)
6. Tape or glue
7. Ferrous metal object such as a pipe or nail
8. Small ferrous object to test with (small screw, nail, etc.)
9. Time on your hands
Remove these ads by
Signing UpStep 1Simon says: Strip!!!
1. Strip the phone lines of their outside sheathing. Don't cut into the interior wires. As you move along, you'll need to use the pliers to push the sheathing off. If you can, try to strip at least two to three feet (that's all you'll need to make this simple magnet).
2. Bare the ends of the wires (If you had to cut the wires, bind the bare ends together to create a long wire and place tape over the bare spots). Now take one end and place it up next to the metal object you wish to make into a magnet.
3. Either glue or tape it into position to prevent it from unraveling.
4. Now start wrapping your wire around the metal object as shown in the video below.
To get a strong electromagnet, you will be basing your build off of what kind of current (amps) you can get, and the number of turns.
The more current you get, the more crowded the wire is for the current to pass through, so it will become hot. To reduce the amount of heat building up, you will want to use thicker wires.
If that's not possible, then perhaps a resistor connected in series would help reduce the current to a level that doesn't heat the wires. You will limit the strength of the magnet by doing this. A lower current can be compensated for with even more turns.
Magnetic force = I * N where as I is current and N is amount of turns.
This is somewhat simplified and english is not my native language. I hope this might help you, or anyone else out there reading this.
its gud
The reason I ask is that I need to create a magnet with approximately 50 pounds of pulling power. This magnet needs to be switched on/off quickly and repeatedly, most likely with a "squeeze" trigger. Can you possibly give me the necessary specs to create this kind of magnet? Thank you very much for your help, and anyone else's suggestions are welcomed and appreciated.
i didn't understood a bit
Good Luck.
CharlieC
Do you have any electronics theory under your belt? Just curious and not meant as in insult, but your ideas are going to hurt people because basically you don't seem to have a clue as to what you're doing in a correct way.
The heat given off it simply the power dissipated by the filament which - voltage across it x the current through it. The current through = the voltage / resistance of the filament.
Other types of lighting, fluorescent, and LED's, for example, use totally different methods of creating light and don't depend on heating something up to make light and are thus much more efficient.
That sums it up pretty well French!
