3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Small Blacksmith's Forge
Step 5LESS FIRE!
LESS FIRE!
To let your forge fire die down simply turn off the air from the blower and leave it. It'll burn down on its own given enough time.
Putting a bucket of water on the forge will be disastrous. You'll get a huge plume of steam laced with incandescant coals, not to mention the fact that you'll give the refractory thermal shock and make it explode. Throwing a bucket of water on it is one of the worst things you can do. Actually, this forge is as safe as a garden barbecueue when handled sensibly but there are serious hazards. Don't let children or animals near it at any times. Don't work if you're preoccupied, drunk or tired.
Read up on the symptoms of carbon monoxide poisoning. If you start to show symptoms, turn it off and get away. NEVER use this in a badly-ventilated area. Always outside.
1 comment
Jul 9, 2011. 10:07 PMacoleman3 says:
something thts real good for dousing your fire is a vegi can with a series of 1/16 in holes in it. the water is reduced to a trickle and is mostly vaporized by the heat of the coals. no popping, no refractory damage and its cooled off in about 30 seconds.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:Vendigroth
I shouldn't have to tell you that using a dagger to undo this little, fiddly screw's a bad idea. AAAAARGH! big project ^^ so practically no chance of instructables from me till july, p'raps? maybe a...
more »
