Make a Small Parts Organizer!
1,751
27
Posted
Introduction: Make a Small Parts Organizer!
I love organizing my shop, so I got these containers to sort all my screws. Whenever I get new boxes, I build another cabinet to hold them. Here is a simple way to do it!
Materials you need:
  • Any scrapwood. I used 20mm Ikea melamin board.
  • Some hardwood or plyood for the rails.
  • Some wood screws. 4.5mm is my favourite diameter
  • 3 or 6mm dowels
Minimal Tools:
Recommended Tools:
Step 1: Cutting the Wood.
Below is a cut list in which you can enter the dimensions of your containers. I used my table saw and a crosscut sled. You can also use any other type of saw, but the table saw is the best for this. Are you new to using saws? Watch a 10min safety video first and save your fingers!
I cut the height of both sides at the same time, this ensures that they are equally long. Some clamps hold them together temporarily.
Cutlist:
2x Side Panels
  • Depth = Container Depth +10mm
  • Height = (Container Height + 5mm + Rail Thickness) * Number of Containers +2 x Width of Top and Bottom Plywood
2x Top/Bottim Panels
  • Width = Width of Container + 5mm + 2* Plyood Thickness.
Rails
  • Number of Rails = 2 *( Number of Containers -1)
  • Rail Depth = Depth of Container (Not critical)
Back Panel
  • Measure it once you got the frame done.
Step 2: Join Your Panels!
I used this dowel jig. It allows you to preciely allign board with each others and also give a strong joint. The jig gives you the exact placement of both dowels and their holes. After this project, I also bought a biscuit jointer and I use it since then. Its more expensive, but a bit more compfortable.
You can also just use plain screws.... Who cares.
Step 3: Add the Rails.
I used hardwood for the rails. You could also use aluminium angle extrusions which should look great. I made a spacer block for the rails and then glued them in place momentarily with wood glue. Wood glue does not stick very well to melamin board. I pre-drilled screw holes and then added screws. This is a bit more work, but ensures good allignment.
Step 4: Final Assembly!
Add some wood glue and assemle the cabinet. The glue does not stick well to melamin, but its good enough. The back also adds a lot of strength.
Feet are very important. At least in my workshop the floor sometimes gets wet and the particle board is great at soaking up liquid.
Step 5: Add the Back.
I glued the particle board to the rails which is a wood to wood bond and very strong with enough wood glue. I also used some staples to fix it in place. A nail gun would be much better but I didn´t had one at the time. I got this one since then and I can totally recommend it.
Measure from edge to diagonal edge. If the distance is the same on both sides, all the boards are square to each others.
Step 6:
And you are done! Now spend a few hours sorting screws : ). Please also send me a photo if you recreate this build! Thanks
  • Metal Contest 2017
    Metal Contest 2017
  • Wheels Contest 2017
    Wheels Contest 2017
  • Remote Control Contest 2017
Questions & Answers
