Make a Socket Clip
4,982
40
6
Posted
Introduction: Make a Socket Clip
Don't you hate it when the socket you need is lost in the bottom of your tool box, just rolling around loose and you have to pull everything out to find it... Well no more!  You too can make the socket clip and have your sockets neat and handy.  Just a few minutes, some simple tools, and your tool box is organized like never before.
Step 1: You Need a Wire Hangar
What you need: a wire hangar, needle nose pliers, regular pliers, and some sockets needing to be organized.
Step 2: Cut Out the Bad Part
Using the wire cutter jaws on your pliers cut the hagar just below the twisted part.  We really dont want to try and straighten that out so just cut it off.
Step 3: Straighten It Out
Now straighten out the hagar so it's one long peice of wire.
Step 4: Bend a Hook
Using your needle nose pliers bend a little hook in one end of the wire.
Step 5: Measure and Bend Again
Line up your sockets.  Bend your hook over so it's 90 degrees to the wire.  Bend the wire below the last socket so it's pointing the same direction as your hook.  Then I use the width of my pliers as a guage and bend the wire back up to the hook.
Step 6: Cut, Wiggle, Clip
Cut the top of your wire just above the hook.  Then using your needle nose pliers bend a little 'wiggle' right where the wire meets the hook.  Don't make the wiggle to big or the sockets won't slip over it.  And we're finished.
Step 7: Sockets Organized
Slip your sockets on and clip it closed.  You may need to adjust the width of your hook so there is just a little resistance when it clips closed; that way it won't come open in your tool box.  Your sockets are now organized and ready when you need them.
Step 8: Enjoy Your Success
Here's the small tool pouch I carry on my motorcycle.  The clips only hold three sockets each but it fits in the pouch just fine.
The first time I posted this instructable I took a little criticism because I called it a holder.  It's not... it's just a big clip or safety pin.  Yes you will have to take all the other sockets off to get to the one you need and put'em back on to store them.  If you like it... great!  If you improve it or change to suit you... even better.  In the world of DIY YOU is the most important part.  Remember, I'm pullin' for you... we're all in this together.
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    6 Comments
    I use a similar design for holding bait on my crab nets
    You know I've been taking these clips underneath the car with me for the last 34 years. Here are a couple pictures of my first one I made in 1978. Still have it in my tool box and still use it. You'll notice I've changed it a bit to make it a little more user friendly. Thanks for your comments. WS
    Thanks for pulling for us. We are men. We can change if we must, I guess. (I appreciate your reference to Red Green.)
    Thank you for the idea. I have thought I need something like this. I frequently think I have accurately judged the size of a bolt or a nut, only to discover I need to crawl out from under the car and try again. This would allow me to get the right socket without climbing out from under the car again, and again.
    Yep, I do that every time. And rather than just getting the whole socket tray to begin with, I go back and forth 3 times with different sockets before I finally get it right. It doesn't make much sense.
    Thank you! I wish Red Green was still on the air in my area. WS
    Along with commercial rail holders I've made these:
    http://i.imgur.com/tw8Tr.jpg
    But they are a bit of a pain to make, so I came up with another way of making random access socket holders with just wire that work like pouch tape holders. The trouble with holders like yours is if you need a socket in the middle you have to dump all the ones before it to get to it.
