3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Solar DS "light" (Version 1)
Make a Solar DS \"light\" (Version 1)
The Nintendo DS Lite seems like it was made to have solar cells put on it. It has a large amount of surface area on the top and bottom that both face upward when the DS is opened. The top and bottom faces each have exactly the right amount of room for two 60x60mm solar cells side by side (four total). Each one has a maximum power output of 3 volts at 40 ma. The top two are connected in series and so are the bottom two. These two sets are wired in parallel to get a total of 6 volts at 80 ma, perfect for trickle-charging the battery.
Note: A newer version has been posted and is better than this one. Go to: http://www.instructables.com/id/Solar-DS-quotLightquot-Redone-and-Greatly-Impr/ for a better version. If you want to make a solar powered DS the easy way, you can still use this one.
If you have a question, don't hesitate to ask!
By the way, this is my first Instructable!
Step 1Materials
Materials
You will need:
  • 4x - 60x60 mm solar cell
  • 2x - Diodes (Preferably schottky, they have a lower forward voltage)
  • Some wire, almost any kind will work (the thinner the better)
  • Scotch tape
Tools:
  • Multimeter
  • Mire stripper / cutter
  • Soldering iron with solder
  • Helping hands tool (not necessary, but helpful)
  • Hot glue gun with glue
213 comments
1-40 of 213next »
Mar 8, 2011. 7:11 AMimgarret says:
Can this be adapted to work on a DSi using the charging port? I'm wondering if you can cut a charging cable to plug into it, instead of running wires directly to the battery?
Thanks.
Mar 21, 2010. 2:57 PMcalalbe says:
 Did you hear about the larger DS XL coming out? Maybe this means we can tack on more panels?
Jan 7, 2010. 3:30 PMPikminRed says:
I WANTED TO MAKE THIS FOR A LONG TIME!!!!!!!! OMG SOMEONE DID IT
Aug 3, 2009. 11:39 AMZetta master says:
Is there anyway i could make this for my DSi or PSP???
Jun 21, 2009. 12:22 PMluka1184 says:
Hi i need to know how to make a DS charger, out of my DS Lite Car Charger it would be for a Lite, cause i got the new Deltora Quest DS Game and its japanese. I need a charger because all my chargers always got stoled or i really dont know if i just trew it out somehwere and cant find it. I want to make it so the volt is circa maching cause to not torching the ds or the cable. ANd i need to cover the wries so i not get torched or gets an electrical shock. (Can i buy a DS Lite Charger in Fona??? If you know what that is, or in Expert if you know what that is, or where else could i buy a brand new one Nintendo DS Lite Charger Dark Sponge????????? (PS: I lives in the country Denmark)
Jul 29, 2009. 8:48 PMpancho del rancho says:
get a normal input and cu it in halft strip the red and black wire then cut the car charger in half and strip the wires then put the red with red and black with black solder or e-tape u need to make sure its the same voltage
May 30, 2009. 3:28 PMdagenius says:
oooookkkkkkkaaaaaaayyyyyyyyy.......
Feb 24, 2009. 6:13 PMPATALIM says:
This is really nice, except that I can't play the Nintendo DS Lite outdoors as I'm having trouble seeing the screen especially when it is too bright.
Feb 26, 2009. 5:27 PMPATALIM says:
Oh!, anyway I think in doing so will shorten the life of your LCD screen as heat will degrade the screen (not to mention other parts such as the casing) as I have proven it to myself with my other LCD devices such as: Wristwatches, Calculators, 2-Way radios, Original Game Boy, GB pocket, Caller ID, etc. that was placed/stored in a warm to hot room or directly being exposed to sunlight and the degree of degradation depends on the quality of the LCD. e.g My Casio watches LCD degrades a little vs my Timex watches and other noname calculator vs branded ones. Hope that the LCD of the Nintendo DS Lite is far superior than its predecessor. (So, now I learned my lesson I'm keeping all my LCD'd devices in a cool place). By the way I from a tropical country.
May 30, 2009. 3:35 PMdagenius says:
well, for one, the screen is facing down while chargeing solar.
Jul 6, 2009. 7:17 AMsmtgr14 says:
I used heat sheilding similar to what they use on the space shuttles and i can leave the DS out all day without any damage.
Jul 7, 2009. 9:35 AMsmtgr14 says:
Sorry but no, i dropped the D@#$ thing and it broke itself and my toe.
Aug 1, 2009. 5:18 PMsmtgr14 says:
Will rebuild eventuall and post pics. also my toe is better now
Mar 8, 2009. 7:26 AMDELETED_5921400 says:
(removed by author or community request)
May 30, 2009. 3:31 PMdagenius says:
IDK... maybe it's 'caus his picture is inapropriate...
Apr 6, 2009. 9:51 PMyummahcupekakez says:
I know someone must have been STUPID.
Apr 23, 2009. 4:33 PMBigev says:
Methinks, when you die, all your comments go bye-bye. Look for their page, it doesn't exist.
Apr 28, 2009. 1:30 PMjakesllama says:
so cool i have experimented with solar panels and made a generator that goes on to your arm so while you move your arm you charge your ds but the problem i had was the ds had charged up in flicks so it would flick on flick off and i ended up damaging my battery lol not very effiicent when the light on the ds go on when charging wasting electric
Apr 21, 2009. 10:43 AMOUSooner says:
How comfortable is it to hold? How strong are the solar panels? Do I need to worry about breaking them if I drop it? Thanks and awesome idea!
Apr 12, 2009. 11:03 AMWoshmistro says:
is it possible to connect the solar panels to the charging slot at the back of the ds so it uses the ds' own cutoff chip and you can see wether the ds is charging with its indicator light?
Apr 12, 2009. 11:08 AMWoshmistro says:
oh soz i should of read through the comments before i posted, anyways... this is a great idea, could save alot of money in the longterm
Apr 9, 2009. 7:23 AMHAL 9000 says:
Hey, i like this! i just got an msi WIND about a month ago, so now im thinking about how to mount solar panels on top. i've been looking around the WIND forums and i have yet to see anyone with a solar trickle charger mounted to theirs.
Apr 6, 2009. 3:53 PMbeauwalker23 says:
how long does it take to completely charge? does it hold its charge? anyone you know ruin their DS?
Feb 24, 2009. 6:59 PMsahervey says:
How durable are the solar panels? I have three kids with DS's and would like to try this. Would the suffer the abuse of a 4, 6, and 8 year old? I am thinking I might be better off simply going with a separate charging pack like the one you have drawn. Will a 9v battery completely charge the DS?
Apr 9, 2009. 7:26 AMHAL 9000 says:
there are solar panels available that are not made of glass and that are almost indestructible. they're flexible, and i think you may even be able to cut them out with scissors to fit. the only downside is that they are a bit more expensive, but they will look pretty slick, since they're paper thin.
1-40 of 213next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
72
Author:dark sponge
Hi! I've loved electronics and electricity for as long as I can remember, and electric projects are something I do in my free time for fun. Everything I've learned about electricity is either from exp...
more »
