Check out the video below to see how much voltage you can get from just four diodes.
Remove these ads by
Signing UpStep 1Silicon Diode
A silicon diode is a two-lead semiconductor that gates current flow in one direction. The symbol below shows how a diode is lined up with the schematic symbol. The image was taken from http://www.gadgetjq.com/single_fire_tach_adapter_diode.jpg for copyright purposes. Diodes are used in circuits that convert AC voltages to DC voltages, and also as voltage regulators, clamps, and multipliers.
Current flows in the direction of the arrow. A few other terms of technical use are:
Forward-biased is when the anode is more positive than the cathode, and reverse-bias is the opposite: the anode is made more negative in voltage than the cathode.
There are different kinds of diodes, too. Pin diodes, germanium diodes, schottky diodes, rectifier diodes (p-n junction diodes) name most of them. In this instructable we're going to work with silicon-based pin diodes, although if you're really curious I'd encourage you trying the different kinds of diodes to see how it all shakes out.
Diodes are pretty cheap. You can pick up a pack of 50 from Radio Shack for around $3.
Regards
Vout = 2D - (2 * Vin)
I wonder, though, how much of an AC voltage swing you'd get if you're pushing, say, 10 uA. Sadly, I'm not sure it could even meet the charge pumps Iin requirements. It would be interesting to see if you could get 120 or 240 VAC from it, though.
Foe those of you who do not know what these are, they were square pices of metal. Usually about 3" by 3" and about 1/32" thick. They were stacked with spacers between the plates and anywhere between 6 and 10 plates per rectifer. Now you can replace then with 1n4004 diodes.
Dave
Cheers!
I used only 2 zener diodes (I think 5v, but not sure) and got up to 2 V in parallel and even 3 V in series, though I did not manage to light up an LED. But I am planning to try buying more of these diodes and making a whole PCB full of them or something and see how much power I can get. I'll let you know.
Cheers,
/nev/dull
Also, you'll get a higher voltage across the system if you place the diodes in series...
...then again, there's also the fact that a 1N4148 diode has a forward voltage-drop of ~0.5V, so I'm not sure if that would affect the operation, or not..
-----o---------|<|-------o------|<|-------------o
... ETC ...
there's a tradeoff between increasing I and increasing V when configuring your diodes in parallel or series.
