Make a Super Bouncy Ball
 by pudi.dk
Featured
Welcome to my instructable, where I will tell you how to make a great little toy using a chemical reaction, and easy-to-get chemicals.
Great science-fun for kids too!
Step 1: Materials needed
This bouncy ball is made using a reaction between the two following chemicals:
- Alcohol (Ethanol) - You should be able to get this at any supermarket.
- Water glass (Sodium silicate) - Pretty easy to find at ceramic supply stores drug stores and hardware stores. I buy mine for about 3$ per 1/2 litre.
You will also need:
- Disposable rubber gloves
- 2 small beakers
- Popsicle stick
... and that's it! Now that wasn't so bad at all, was it?
1-40 of 201Next »
magey00 says: May 23, 2013. 4:36 PM
I really cannot find the place that I can buy a sodium silicate....I've called Hobby Lobby, Target, CVS pharmacy, Quick pharmacy, Lowe's, HEB, and the Home Depot and ask if they have "Sodium Silicate" or "Water Glass", but none of them have it.... Please help me
tonytaylor85 says: Jun 29, 2012. 8:06 AM
I work for a silicate plant. I'll try some different grades and ratios next week and report back what works best. My guess is that RR will work best, but we will see.
Here is a property data sheet for the grades we make:
http://www.pqcorp.com/LinkClick.aspx?fileticket=pMka9UCMEiU%3d&tabid=143&mid=585
Chemmagic says: Mar 28, 2012. 5:08 AM
I can't get my ball to form. It goes as far as the paste-like stage and then thats it.
I'm in a well stocked Chemistry lab with a new 2.5L container of sodium silicate, fresh Ethanol and phenolphthalein, I've also tried using isopropanol but nothing is working, i just have lots of beakers of goop.
Someone please please help!!!
pudi.dk (author) in reply to ChemmagicMar 28, 2012. 7:11 AM
What concentration is the ethanol? It should be pretty close to 100%, typically 96% or so although many labs use 70% for the sake of sterilization, that might be why you are getting the 'paste' from excess water.
If you have enough chemicals to experiment, try using different ratios of silicate:ethanol that might work better.
Chemmagic in reply to pudi.dkMar 28, 2012. 7:43 AM
it's absolute, Ive tried different ratios, Ive tried isopropanol, ive just had a go with methyl alcohol...still no luck :(
maxthecat1 says: May 23, 2009. 6:19 PM
my bouncy ball breaks very easily. how can i get it so it doesn't break apart? and it also dries out quickly. I am using rubbing alcohol instead of ethanol. is that the problem?
mashedpotato13 in reply to maxthecat1Aug 11, 2009. 8:54 AM
well rubbing alcohol is mostly ethanol mixed with a little bit of water. so it should'nt be the problem...
lifelong-newbie in reply to mashedpotato13Sep 3, 2009. 2:19 PM
Unless the water is evaporating out, causing the drying effect
Ugifer in reply to lifelong-newbieJan 28, 2012. 2:41 PM
I think rubbing alcohol is actually isopropyl alcohol rather than ethanol. Not sure what is going on here chemically so I can't really say whether it will make a difference but rubbing alcohol and ethanol are not normally the same thing.
jpetty1 says: Nov 26, 2011. 9:54 PM
does it dry? If I add 4 cups to 1 cup will i get a bouncy ball?
jpetty1 says: Nov 26, 2011. 9:51 PM
Is in a 4:1 ratio?
AKA=THE SNOWMAN says: Mar 15, 2009. 1:54 PM
i used liquid glass with metallic in it. . . . havent tried it yet. . . .will post my results in a few minutes. . .nice instructable!!!!
dombeef in reply to AKA=THE SNOWMANJul 14, 2009. 4:19 PM
When...
beehard44 in reply to dombeefAug 20, 2010. 4:05 AM
still waiting.....
dombeef in reply to beehard44Aug 20, 2010. 9:22 AM
still waiting too
Win Guy in reply to dombeefApr 4, 2011. 12:43 AM
Uhhh... lol
dombeef in reply to Win GuyApr 4, 2011. 3:52 AM
Yeah, any day now!
gario10 in reply to dombeefMay 7, 2011. 1:24 PM
Almost
vman3 in reply to gario10Jul 31, 2011. 9:28 AM
I have a small feeling he forgot...
mattman2 in reply to vman3Aug 16, 2011. 11:52 AM
been waiting for a while now
pudi.dk (author) in reply to mattman2Aug 16, 2011. 2:20 PM
I'm waiting eagerly as well!
TandemFixation in reply to pudi.dkSep 6, 2011. 12:09 AM
I'm pretty sure it exploded on him. :-) Not all those who discover explosives live to tell of their creations ;-)
TechNerd1012 in reply to TandemFixationOct 23, 2011. 11:29 AM
still waiting
flio191 in reply to TechNerd1012Oct 23, 2011. 12:17 PM
AKA=THESNOWMAN has accidentally created a miniature black hole through his/her efforts and is now somewhere far in the future, being lectured about why not to mix liquid glass with "metallic" by non-humanoids in a language he/she cannot understand.
blinkyblinky says: Oct 23, 2011. 9:36 AM
I Love It.
What is your nationality?
pudi.dk (author) in reply to blinkyblinkyOct 23, 2011. 11:55 AM
Thanks!
I'm from Denmark.
spenfisher12 says: Nov 16, 2010. 7:25 PM
3 CHEERS FOR POLYMERS WITH OUT,EM GLOCKS WOULD NOT BE THE SAME GUN AND THIS IBLE WOULD NOT HAVE BEEN MADE
hjjusa in reply to spenfisher12Oct 23, 2011. 9:08 AM
Have you seen tat video where they they dragged a Glock behind a truck over a dirt road? It bounced pretty googood and still shot like a champ when it was over.
josh1324 says: Jul 31, 2011. 10:12 AM
nice 'ible! 5*!
Katrien95 says: Nov 17, 2010. 10:25 AM
Is there a connection between the quantity of the alcohol and waterglass and the ability of bouncing (for example, if you take less alcohol, the ball should bounce higher and better.) This is an example! Just to prevent misunderstandings...
mdeblasi1 says: Jan 27, 2009. 11:02 AM
Could someone explain what is going on here chemically? What is sodium silicate, what happens to it in the presence of alcohol? How is it that the ball can be reformed after all the alcohol should have long evaporated off? Finally, why is polymerized (?) Sodium silicate so bouncy? Cheers, M
mdeblasi1 in reply to mdeblasi1May 8, 2009. 2:19 PM
'"In Sodium Silicate, the Silicon is bonded to 4 oxygen atoms and is not linked in any chains. The Ethyl Alcohol has just two Carbon atoms. When Sodium Silicate and Ethyl Alcohol are put together, the Silicate particles begin to link up with each other to form long chains as the Ethyl groups replace Oxygen atoms in the Silicate ion. Some become cross-linked between chains. Water molecules are byproducts of the formation of the polymerization bond. This forms a large molecule - a Silicone polymer"
Thank you United Nuclear. This begins to explain things.
beehard44 in reply to mdeblasi1Feb 13, 2010. 1:50 AM
in short, alcohol+water glass= one hell of a frickin bouncy ball
Shinta786 in reply to mdeblasi1May 8, 2009. 12:00 PM
well.....they react with each other......and you get a bouncy ball, lol.
msuper28 says: Sep 10, 2009. 3:31 AM
(removed by author or community request)
pudi.dk (author) in reply to msuper28Sep 10, 2009. 1:46 PM
Water instead of sodium silicate? Congratulations you have just diluted alcohol!
beehard44 in reply to pudi.dkFeb 13, 2010. 1:47 AM
lol
kcls says: Jan 6, 2010. 10:49 AM
If I wanted to put something inside, say, a polymer clay giraffe, is there a way to make it clear so i could see him? Just a thought...
warhawk97 says: Jul 25, 2009. 3:05 PM
Awesome! Just wondering if you can put in some food collaring?
kate_27 in reply to warhawk97Oct 13, 2009. 6:34 AM
 You should be able to, try it!
1-40 of 201Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
