3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Super Bouncy Ball
Welcome to my instructable, where I will tell you how to make a great little toy using a chemical reaction, and easy-to-get chemicals.
Great science-fun for kids too!
Step 1Materials needed
Materials needed
This bouncy ball is made using a reaction between the two following chemicals:
- Alcohol (Ethanol) - You should be able to get this at any supermarket.
- Water glass (Sodium silicate) - Pretty easy to find at ceramic supply stores drug stores and hardware stores. I buy mine for about 3$ per 1/2 litre.
You will also need:
- Disposable rubber gloves
- 2 small beakers
- Popsicle stick
... and that's it! Now that wasn't so bad at all, was it?
199 comments
1-40 of 199next »
Mar 28, 2012. 5:08 AMChemmagic says:
I can't get my ball to form. It goes as far as the paste-like stage and then thats it.
I'm in a well stocked Chemistry lab with a new 2.5L container of sodium silicate, fresh Ethanol and phenolphthalein, I've also tried using isopropanol but nothing is working, i just have lots of beakers of goop.
Someone please please help!!!
Mar 28, 2012. 7:43 AMChemmagic says:
it's absolute, Ive tried different ratios, Ive tried isopropanol, ive just had a go with methyl alcohol...still no luck :(
May 23, 2009. 6:19 PMmaxthecat1 says:
my bouncy ball breaks very easily. how can i get it so it doesn't break apart? and it also dries out quickly. I am using rubbing alcohol instead of ethanol. is that the problem?
Aug 11, 2009. 8:54 AMkill1234 says:
well rubbing alcohol is mostly ethanol mixed with a little bit of water. so it should'nt be the problem...
Sep 3, 2009. 2:19 PMlifelong-newbie says:
Unless the water is evaporating out, causing the drying effect
Jan 28, 2012. 2:41 PMUgifer says:
I think rubbing alcohol is actually isopropyl alcohol rather than ethanol. Not sure what is going on here chemically so I can't really say whether it will make a difference but rubbing alcohol and ethanol are not normally the same thing.
Nov 26, 2011. 9:54 PMjpetty1 says:
does it dry? If I add 4 cups to 1 cup will i get a bouncy ball?
Nov 26, 2011. 9:51 PMjpetty1 says:
Is in a 4:1 ratio?
Mar 15, 2009. 1:54 PMAKA=THE SNOWMAN says:
i used liquid glass with metallic in it. . . . havent tried it yet. . . .will post my results in a few minutes. . .nice instructable!!!!
Jul 14, 2009. 4:19 PMdombeef says:
When...
Aug 20, 2010. 4:05 AMbeehard44 says:
still waiting.....
Aug 20, 2010. 9:22 AMdombeef says:
still waiting too
Apr 4, 2011. 12:43 AMWin Guy says:
Uhhh... lol
Apr 4, 2011. 3:52 AMdombeef says:
Yeah, any day now!
May 7, 2011. 1:24 PMgario10 says:
Almost
Jul 31, 2011. 9:28 AMvman3 says:
I have a small feeling he forgot...
Aug 16, 2011. 11:52 AMmattman2 says:
been waiting for a while now
Sep 6, 2011. 12:09 AMTandemFixation says:
I'm pretty sure it exploded on him. :-) Not all those who discover explosives live to tell of their creations ;-)
Oct 23, 2011. 11:29 AMTechNerd1012 says:
still waiting
Oct 23, 2011. 12:17 PMflio191 says:
AKA=THESNOWMAN has accidentally created a miniature black hole through his/her efforts and is now somewhere far in the future, being lectured about why not to mix liquid glass with "metallic" by non-humanoids in a language he/she cannot understand.
Oct 23, 2011. 9:36 AMblinkyblinky says:
I Love It.
What is your nationality?
Nov 16, 2010. 7:25 PMspenfisher12 says:
3 CHEERS FOR POLYMERS WITH OUT,EM GLOCKS WOULD NOT BE THE SAME GUN AND THIS IBLE WOULD NOT HAVE BEEN MADE
Oct 23, 2011. 9:08 AMhjjusa says:
Have you seen tat video where they they dragged a Glock behind a truck over a dirt road? It bounced pretty googood and still shot like a champ when it was over.
Jul 31, 2011. 10:12 AMjosh1324 says:
nice 'ible! 5*!
Nov 17, 2010. 10:25 AMKatrien95 says:
Is there a connection between the quantity of the alcohol and waterglass and the ability of bouncing (for example, if you take less alcohol, the ball should bounce higher and better.) This is an example! Just to prevent misunderstandings...
Jan 27, 2009. 11:02 AMmdeblasi1 says:
Could someone explain what is going on here chemically? What is sodium silicate, what happens to it in the presence of alcohol? How is it that the ball can be reformed after all the alcohol should have long evaporated off? Finally, why is polymerized (?) Sodium silicate so bouncy? Cheers, M
May 8, 2009. 2:19 PMmdeblasi1 says:
'"In Sodium Silicate, the Silicon is bonded to 4 oxygen atoms and is not linked in any chains. The Ethyl Alcohol has just two Carbon atoms. When Sodium Silicate and Ethyl Alcohol are put together, the Silicate particles begin to link up with each other to form long chains as the Ethyl groups replace Oxygen atoms in the Silicate ion. Some become cross-linked between chains. Water molecules are byproducts of the formation of the polymerization bond. This forms a large molecule - a Silicone polymer"
Thank you United Nuclear. This begins to explain things.
Feb 13, 2010. 1:50 AMbeehard44 says:
in short, alcohol+water glass= one hell of a frickin bouncy ball
May 8, 2009. 12:00 PMShinta786 says:
well.....they react with each other......and you get a bouncy ball, lol.
Sep 10, 2009. 3:31 AMmsuper28 says:
(removed by author or community request)
Feb 13, 2010. 1:47 AMbeehard44 says:
lol
Jan 6, 2010. 10:49 AMkcls says:
If I wanted to put something inside, say, a polymer clay giraffe, is there a way to make it clear so i could see him? Just a thought...
Jul 25, 2009. 3:05 PMwarhawk97 says:
Awesome! Just wondering if you can put in some food collaring?
Oct 13, 2009. 6:34 AMkate_27 says:
 You should be able to, try it!
Oct 3, 2009. 4:35 PMwoody558 says:
Is there any substitute for water glass?
Sep 16, 2009. 9:08 PMGianniMora says:
1-40 of 199next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
59
Author:pudi.dk
