3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Talking Clock
Step 3Recording Your Voice
Let's start by capturing your voice samples.  If you'd rather skip this, you can use the samples I made (download here).
Audacity is a great program for recording audio.  You can download Audacity here.  When using Audacity, be sure to set the track properties to 16-bit PCM, 16khz rate.  Mono is fine, stereo will work, but I only hooked up a single speaker (and why does your clock need to be in stereo?).
Each number gets it's own wav. file.  You'll need the following samples:
Numbers
  • 00.wav
  • 01.wav
  • 02.wav
  • 03.wav
  • 04.wav
  • 05.wav
  • 06.wav
  • 07.wav
  • 08.wav
  • 09.wav
  • 11.wav
  • 12.wav
  • 13.wav
  • 14.wav
  • 15.wav
  • 16.wav
  • 17.wav
  • 18.wav
  • 19.wav
  • 20.wav
  • 30.wav
  • 40.wav
  • 50.wav
words
  • am.wav
  • pm.wav
  • geve.wav (good evening)
  • morn.wav (good morning)
  • anoon.wav (good afternoon)
  • and.wav (and)
  • oclock.wav (O'Clock)
  • secs.wav (seconds)
  • exact.wav (exactly)
  • beep.wav, a beep sound
  • standard.wav (Pacific standard time will be)
  • dlight.wav (Pacific daylight time will be)
Record each of them as separate files and save to the root directory on your SD card.  I recorded all of them as a single wave, then chopped them up into separate files.  It seemed easier to control the volume levels that way.
Also, if you have a laptop, you'll get better results using an external microphone.  Depending on your laptop, you might get some hiss or buzz.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
164
Author:Gadget Gangster(GadgetGangster.com)
