3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Test Tube Thunderstorm!!!
video Make a Test Tube Thunderstorm!!!
In this cool science experiment we make a thunderstorm in a test tube using alcohol, sulfuric acid and potassium permanganate.
WARNING:This experiment is extremely dangerous as it involves corrosive acids and flammable liquids with a small, but not negligible, chance of a damaging explosion. Face shields, goggles, fire extinguishers and fire safety protocols must be present. This should only be attempted by an experienced chemist.
Just get a test tube of 95% alcohol and carefully pipette a layer in a bottom of sulfuric acid. Then drop in some potassium permanganate crystals. It takes a minute or two to start up.
The reaction of the permanganate and the sulfuric acid produce manganese heptoxide that explodes on contact with organic matter like the alcohol. This also works with acetone.
More cool stuff at our website at http://www.nurdrage.com
13 comments
Feb 18, 2012. 10:43 PMabell21 says:
This is a fun demo to do - the problem I had was when I went to dispose of it - a 250ml measuring cylinder half full. I used methanol, as it was cheaper. As long as the alcohol on top was deeper than the explosions, it was good, but when I tipped it, the alcohol layer thinned, ignited, and blew a fireball out. After returning to the vertical, I tried to kill it with water - that caused the acid to boil, and more little explosions. in the end i dumped it into a large stainless sink and waited for the burning to stop :)
You live and learn. Usually.
Now, I work backwards - think disposal first, and have everything thought out and planned before I grab chemicals.
Jan 11, 2012. 12:24 PMsokamiwohali says:
cool cool.. thanks for sharing!
Sep 15, 2011. 4:13 PMtrilo3000 says:
also would changing the variables like how much potassium permanganate is used change the out come? im trying to find a way to create a variable for different hypothesis for a science fair experiment,
Sep 15, 2011. 4:01 PMtrilo3000 says:
where can you purchase the crystals? or would this be suitable http://secure.sciencecompany.com/Potassium-Permanganate-125g-P6403.aspx
Feb 12, 2011. 5:57 PMkill1234 says:
Should this be called 'Firecrackers in a test tube'?
Aug 21, 2009. 6:56 PMjyeomans says:
I'm glad there are science herds like you to conduct cool experiments like this for the rest of us! I'll heed your warning and just watch the video.
Nov 26, 2010. 4:58 AMyeolddingdong says:
how to get sulfrc acid?
Sep 6, 2009. 12:00 AMcasey321b says:
i wont... :D
Aug 21, 2009. 7:14 PMhg341 says:
are you layering it alcohol on bottom or sulfuric acid bottom
Aug 23, 2009. 4:53 AMKiteman says:
Sulphuric acid at the bottom - the thin pipette reaches to the bottom of the tube before the acid is injected.
Aug 23, 2009. 11:47 AMhg341 says:
now i just need to watch there vids on makeing Potassium Permanganate
Nice.
Aug 21, 2009. 5:18 AMBlackice504 says:
That was a really intresting effect. Thanks for another great video.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
614
Author:NurdRage(NurdRage)
NurdRage is a dedicate group of science nerds trying to further amateur science with direct how-to instructions in video format. We saw what was already online and we thought "we could do better"... s...
more »
