3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Scratch Holograms!
Scratch Holograms!
Have you ever noticed ghostly blobs floating above your black car hood on a sunny day? These blobs are scratch holograms! They appear when the sun is reflecting off circular scratches from activities like washing, polishing, or drying your car. They seem to float because each of your eyes sees the suns reflection at a different point, creating a 3D stereo pair.
'This Instructable has two parts:
Part 1: how to make scratch holograms with a compass
Part 2: how to make a device to draw scratch holograms
Step 1Use a Compass to Make a Simple Demo
Let's start off with an experiment. Find a compass with sharp points at both tips (a drafting compass works well). Adjust the compass to about 2" between the tips.
Find a piece of plastic. I use 1/4" black acrylic (polycarbonate and styrene work fine also). The jewel case from a CD works fine but try to find one with a black CD holder insert because the hologram shows up better with a black background. The best scratches are barely visible and don't produce flakes of plastic. Double stick tape will hold the plastic to your working surface.
With the compass slightly angles, gently scratch an arc. Adjust the compass to a different radius, use the same center point, and make another scratch. In the image, I scratched an arc every 1/8" from a radius of 1.5" to 5.5".
38 comments
Nov 28, 2007. 7:30 AMSecondSun says:
blurry stuff does not make a hologram.
Feb 23, 2009. 9:43 AMlasermaster3531 says:
yes it does, you *****. a scratch hologram is a real hologram technique. look it up.
Jan 23, 2011. 10:31 AMSecondSun says:
If scratch hologram is a hologram, then my morning bowel movement is art.
Aug 1, 2011. 6:28 PMbrionic says:
http://www.youtube.com/watch?v=XUy8lELWhJg
Your bowel movements must be amazing.
Apr 10, 2009. 9:53 PMBroom says:
Agreed, lasermaster3531 - and I'm an optical engineer.
Jan 2, 2008. 5:49 PMSecondSun says:
I already have access to one. Its not technically mine though.
Jun 2, 2011. 11:18 AMsuayres says:
To Muffinator: go to your friendly neighborhood Harbor Freight Tools & check out their cheap knockoffs--they work fine.I have one of their flex-shaft tools, and it works great, for not a lot of $$$.
Mar 12, 2010. 8:37 AMstringstretcher says:
Hmmm... I would love to try that Dremel tool in my CNC router! Converting a drawing to Gcode and then turning it into a hologram...
Mar 9, 2010. 4:51 PMmegapix says:
Great instructable! Years ago I got involved with making laser holograms (big laser, expensive optical table, nasty chemicals). Then I started up again when I read about computer generated holograms (it took all night to calculate a single point with my IBM XT). I've seen the 3-d effect of swirls on a car, but it never occured to me that it was holographic. The presentation that you linked to explained it very well. Thanks!
Mar 9, 2010. 2:11 PMLoneWolf says:
A-W-E-S-O-M-E
May 13, 2007. 1:45 PMT3h_Muffinator says:
This is really, really, super cool! Too bad I don't have one of those fancy dremels!
Nov 24, 2009. 11:00 PMZirconFive says:
Hi, I like your Instructable.  I was wondering if you had any scratch hologram designs plotted.  I figured out the cube, and I just figured out how to do a pyramid.  I figured maybe someone had already figured out some more 3D shapes.   Here is a rough sketch of my pyramid plot.  They should all be squares.  Oh well.  I will try to add dots in between the corners too.
                               |       ________________       |
                               |      |      __________     |       |
                               |___| __|__________|__|___ |
Nov 24, 2009. 11:01 PMZirconFive says:
:( it looks like my plot didn't work...
May 14, 2007. 5:59 PMT3h_Muffinator says:
I know, I know... It's just that I recently bought a welder for $200, and I don't think my parents want me spending any more monies on tools for at least two months. Thanks!
Jun 1, 2009. 5:48 PMdombeef says:
Two Months?!?!??? If I bought a welder they would not let me buy things for a year!
Jul 5, 2009. 10:39 PMgirrrrrrr2 says:
if i bought a welder i would have no money to spend on metal to weld... and then would sell the welder to make money... and then would spend the money on metal only to realise that i just sold my welder.
Jul 6, 2009. 9:13 AMdombeef says:
Yeah lol
Nov 24, 2009. 10:45 PMZirconFive says:
Making a 3D cube is easy.  I don't have a dremel, I just use a compass.  I bought some black acrylic, but I started on CD cases with black backing.  Get a compass with 2 sharp ends.  Scratch a 2x2cm square on the surface, you can scratch deep, this is a guide for one compass point.  Set your compass to 2cm.  Hold one point on the corner of the square and very gently drag your other compass point in an arc across the surface.  Move your guide point over a tiny bit and do another scratch.  The scratches should be very close together, they will overlap in places.  The more scratches the better, you can get very sharp lines if you take the time.  You don't want to scratch deep enough to displace any plastic, just create tiny grooves.  When you are finished with your square, increase the width of your compass a tiny bit and do scratches on just the four corners of the square.  Continue increasing the width of the compass (the depth/height of the hologram) and making scratches from the corners until you have reached 4cm.  Then do a second full square, following the same guide from the first square.  Then go put your hologram on the ground in the sun, in between you and the sun.  If the arcs of the scratches are arcing toward you, you will see the cube sunken beneath the surface.  If you turn it around the cube will float 2 cm above the surface.  All my friends are amazed.  I am trying all kinds of stuff, but I don't know any algebra.
Jun 10, 2008. 11:12 AMhornbadoing says:
you ar my hero <3 lol jk but awsom
Jun 1, 2009. 5:45 PMdombeef says:
"Heart Laugh out loud joking"
May 19, 2007. 8:54 PMmastercheeser says:
i think those are holographs not holograms cuz holograms are projected in threedee
Feb 23, 2009. 9:48 AMlasermaster3531 says:
if you do these right they are 3D. you need algebra equations to make a cube or a tetrahedron etc, but you can do it. these instructions tell you how to make a flat image floating in the plastic, but complex 3D images are possible, too.
Jul 5, 2008. 6:46 AMinvisiblelight386 says:
if you are doing these by hand try using black CDs. i tried it with black Memorex CD-Rs
Feb 10, 2008. 2:49 PMDamionLee says:
Nice idea, definitely worth some time playing about with. Have a few ideas of what I'll be trying. Thanks. For clarification the correct term is indeed hologram (which has nothing to do with projection of images). Confusion arises from the term 'holography' which is a photographic technique to produce a 3D image. These 3D images are called holograms. A holograph is actually a text document which has been hand written by the same person that signed it. Easy for the terms to be crossed over though.
Oct 19, 2007. 5:24 PMlordoffire says:
hmmm....very interesting
May 13, 2007. 1:54 AMVIRON says:
Scratch holograms are great. I've been pondering a way to make a sundial effect so that you get different messages, or the time of day.
May 13, 2007. 9:45 PMVIRON says:
Yes, digital sundials work in a way similar to lenticular lenses.
May 15, 2007. 3:08 PMVIRON says:
Bill Beatty explains how to hide images behind other ones, but as I understand it, by stopping the arc, so I'm not sure how or if that effect could be done with circles. I liked your prototype that was based on the compass and it gave me the idea of having the cutting pins moveable along the diameter to change the side of the circles. Does having two or more non-central pins help besides balancing the motor?
May 14, 2007. 12:38 PMVIRON says:
Gibbon, just curious, can your tool make images with depth like a cube, or only floating ones like written words? I'm assuming you have to move the pins to make a different level of depth; does centifugal force increase the depth when you speed up the dremel by moving the pins further apart causing bigger arcs? Collaborating... :)
May 14, 2007. 7:32 AMrimar2000 says:
Awesome, congratulations. I was'nt try it, but it seems very interesting.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:gibbon
I'm looking for new ways to maximize leisure time. If any of you brainiacs have a how-to for that, please fill me in.
