Introduction: Make a Trashcandlestick
Picture of Make a Trashcandlestick
My daughters “Harakuma” perfume bottle was empty. It was a shame to throw the beautiful lid away, so I decided to make a candle stick out of it. Which trash do you have to transform into a candlestick? Don’t panic if you don’t have a Harakuma perfume lid, you can also use toys, old vases or a Chinese dog for example.
Step 1: What You Need
Picture of What You Need
This is what i used to make the candle stick:
trash
a (pillar) drill
pencil, ruler
wood I used Birch
chisel, mallet
saw
lathe, turning tools such as parting tool, spindle gouge, roughing gouge,
sanding paper (240 grid)
paint color
glue I used Power epoxy
copper tube Length 2.8 inch, 0.8 inch diameter
pipe cutters
brass polish, or citron, tomato ketchup........
a rasp
tin foil
copper coin
soldering iron
solder
candle
Step 2: Prepare for Turning
Picture of Prepare for Turning
Cut your log in the right size.
Mark the center on both ends.
Make an incision with a chisel on one end for mounting the log in your lathe
Step 3: Turn a Base
Picture of Turn a Base
Start turning and turn at slow speed until your log is round. I started with a roughing gouge.
Mark the beginning and the end of the base with parting tool.
Turn the base and "the copper tube holder" and measure the width so you can mount the copper tube. I mostly used my spindle gouge.
Sand your base.
Step 4: Paint the Base
Picture of Paint the Base
Protect the environment.
Spray several layers of paint on your base and let it dry.
Use gloves and dust mask to protect yourself.
Step 5: Cut the Copper Tube
Picture of Cut the Copper Tube
Cut the tube with a pipe cutters
Smoothen the inside of the tube with a rasp.
Sand the edges with sanding paper.
Polish the tube with brass polish.
Step 6: ​Fire Prevention
Picture of ​Fire Prevention
We don’t want to set the house on fire. So we are going to solder a copper coin in the tube this will prevent that the burning candle reach the wooden base.
Chose a copper coin that fits in the tube, or make it fit. I used a rasp to grind the edges. Put some tin foil in the tube this will hold your coin on the right place. Solder your coin. In this instructables tells Noahw how to do it: https://www.instructables.com/id/How-to-solder/
Or if you are too tired you simply fill half of the tube with tin foil.
Step 7: Drill a Hole in the Lid
Picture of Drill a Hole in the Lid
Mark where you want to drill.
Drill at slow speed.
Try to find a drill in the same size as your copper tube.
I had to sand the hole a little bit bigger to fit the copper tube.
Step 8: Mounting Your Candle Stick
Picture of Mounting Your Candle Stick
Prepare
your glue and use gloves you don’t want the glue on your fingers
Put the copper tube in the lid (the doll) and glue the doll and copper tube on the base
Let the glue dry
Step 9: Before and After
Picture of Before and After
Before an empty perfume bottle and now a beautiful candlestick
Before an old Chines dog and now a new candlestick
Before an old toy and now a toy candlestick
If you like this project, please consider to vote for me. Thank you!
About This Instructable
525views
4favorites
License:
Bio: Hi I am Dutch and live in Sweden. I love to create things in my little woodshop.
More by Amaries:Woodenleather BagDog Lamp InstructableMake a Ring With Hardwood and Silver or Copper
Add instructable to:
