Make a Tree from Jewelry Wire
This instructable will show you how to make these fantasy style trees using jewelry wire. They are fairly quick to make, taking only an afternoon for me to make one for me, and could probably be done quicker. They don't need much concentration to create, so are great to make while watching tv.
*edit* just a typo!
Step 1Materials Needed
Materials Needed
To make these trees, you will need just a few materials:
Jewelry wire (mine was 24 gauge gunmetal), about 70 or so yards, more for thicker wire, less for thinner. Really any pliable wire will do, though it's harder the thicker you go.
Beads: Either seed beads, or larger spherical beads
Wire Cutters: If you have a small enough gauge of wire, you may be able to use scissors as I did
A ruler or other measuring implement, if you can't find one, it's not too important
Pliers: If you have a thicker wire, you may need these to help further on
43 comments
1-40 of 43next »
May 27, 2010. 1:44 PMnickodemus says:
Here's mine! I also made a smaller one from aluminum wire, I'll post some pictures of it when I get a chance.
Jun 1, 2010. 12:22 PMfrenzy says:
This Instructable has won the "I Made It" Challenge, Thanks for being a part of the instructables community!
http://www.instructables.com/community/June-is-I-Made-It-Challenge-Month-Win-a-Pro-Mem/
Dec 23, 2011. 9:45 PMcryslhooq says:
how did you make the trunk for the first one you did? I am using welding wire (.035) which is evilly stiff like your 18 gauge wire, but you manage to get the trunk to twist nice and tight. your reply would be much appreciated.
Thanks
Dec 1, 2011. 6:34 AMBonsaiArt says:
I'll try once again...
Apr 26, 2010. 11:20 AMFACEfun says:
This is my first one, and I believe it turned out relatively well. I didn't have much wire, I only used 60 strands, so it's small.
Sep 22, 2011. 9:55 AMwhatnext says:
This is so beautiful!! Do you know what size pearls you used. I just bought 4mm plastic pearls online and i want to buy another color so I am hoping they are the right size. Also, did you use two different sizes of beads? Did you use stainless wire? do you remember what size the wire was? Sorry for all of the questions, I really love your tree. So much, that I am going to try to replicate it. Thanks! and great job! Really.
Jan 25, 2011. 9:45 AMtpayne15 says:
i wanted to do something like this for my wedding guest list (build a big tree then have guests write their names on a leaf and hang them from branches)..but how much wire do you think thatd call for...the guest list is at least 100ppl?
Sep 5, 2011. 5:32 PMMirth Krafter says:
I tried making a nice tall tree and found that the weight of the beads made it a weeping willow instead of a upright tree. I used floral wire and it just wasn't strong enough to stand up on its own until I fed super glue into the trunk. My final tree is about 1 1/2 foot tall plus the basket it sets on.
If you are still trying it I would strongly suggest putting a dowel rod in the center of the trunk and hide it with the wire.
Floral wire is still a good choice. The last suggestion is that you don't cut the branch ends and leave them as loops. This will help in three ways; first it will leave you with no sharp ends. Second you will have stronger branches. And third the loops will give you something to hang the tags from, try small paper clips.
Floral wire is cheaper, yet the correct color for a tree. Expect to use 3-4 or more paddles.
Congratulations on the wedding.
May 9, 2011. 8:09 AMalexiabueno says:
wow, that's such a great idea. and although you're not directing your question at me, i believe it should be no more than $50 worth of wire (get it at a hardware store, craft store wire is pretty pricey) but you will have to consider all the time (and patience) it would take for it to be built.
May 9, 2011. 11:13 AMtpayne15 says:
Thanks for your help! We have plenty of time before the wedding. Ill head over to lowes or home depot and see what they have. And ill definitely post the end result.
May 18, 2010. 11:00 AMyordun says:
 Where can you get jewelry wire, and what it is exactly? Nice instructable, by the way.
Jun 28, 2011. 11:24 PMcboyer2 says:
For trees I would save money and get wire at a hardware store as the stuff you get at craft stores is more expensive. Unless of course you want your tree to be green or something along those lines, then you might want to get the colored wire. Check online pricing before going to your local store to see if you can find the same thing less expensively.
You also have the option of pickling the copper wire to get a verde gris (green) effect.
May 20, 2010. 4:11 PMGeekyGirl1103 says:
Jewelry wire can be found in Michaels or WalMart by the beads. And it comes in many different colors. :)
Jun 28, 2011. 6:04 PMHoooyyat says:
Thanks for the instructable. To get everything together and to finish it took me about an hour. Im thinking of using this technique to make framework for a fake bonsai tree but until then I have this.
Jan 19, 2011. 11:18 AMfreaknuggetz_chick says:
thank you so much for this instructable! WOW!!! i was looking for that 'perfect' gift for my sister-in-law, and this was it. As the tree was intended to hold her jewelry, i used a heavier guage wire. but this made the roots too short, and it had to be 'potted'. i stuck the roots to an inverted plastic plant pot, and then placed that in the nice ceramic pot. Plaster of Paris was used to be the main base, and some extra beads and crafting glue decorated the top of the paster.
Jul 9, 2010. 7:21 PMsoumik_born_to_learn says:
here is my first one... I didnt had much supplies...
Apr 30, 2010. 8:11 PMcherub6694 says:
What a great idea! After receiving a mini bonsai tree kit for a present, I conducted some research on the topic. The jack pine seeds included in the box were not considered a great starter bonsai, and I didn't want to kill a tree. So, I decided I wanted to make a bonsai tree. I ended up making a smaller version of this wire tree with gold jewelry wire. Instead of using beads for leaves, I twisted the wire around some decorative green rocks. It looks very nice; thank you for the clear and beautiful instructable.
@FACEfun and vIDO- Your trees both came out wonderfully. I especially like the one vIDO made for the wedding.
Mar 14, 2010. 11:09 AMvIDo says:
what can I say..  I really had noting better to do today..
thank you for the lovely ible!
Mar 14, 2010. 7:23 PMTheFawns says:
 OMG! awesome!! lol
Mar 14, 2010. 11:34 PMvIDo says:
thank you.. :D
personally I don't like the beads on this one. but I didn't have anything else and the shops are closed on Sundays.. :(
I'm thinking of making a big one as wedding present for my aunt. I was thinking about maybe making it look like two trees that have grown in to each other.
if I don't forget I'll post a picture.
~vIDo
Mar 18, 2010. 3:07 PMTheFawns says:
 i think it looks just fine :) it kinda reminds me of those trees with the white flowers on them, if the wire was like a purple color it would look even cooler :D
Apr 11, 2010. 3:14 PMvIDo says:
about a month ago I told you guys I was thinking about making one as a weding present for my aunt.. and I did..
~62 meters of wire.
~180 beads (three diferent colors of small wooden ones and 8 (fake) pearls)
and a 6 kg rock
ps. this is somewhat of a WIP. I'm trying to get a little engraved plate on the front with there names and the date.
Mar 16, 2010. 12:10 AMvIDo says:
I don't think you should over do it with th colors. ether take  colors that aren't to far apart  (like different shades of the same color) or if you use some completely different color only do a few. (like I did here)
but hey, I'm no expert... the only way to really find out what looks best is to try them all :D (I'm going to need more wire >.> )
~vIDo
Mar 15, 2010. 8:26 AMdanlab says:
I've cut a lot of pieces of wire to certain lengths for my job and I figured out one of the easiest was of measuring is to put two pieces of masking tape on the side of the table at the distance you want (50 cm in your case). Then you can put the spool by one tape, pull the wire close to the other tape and snip it off at the spool.
Mar 17, 2010. 10:01 PMverybluesky says:
It's people like you that make this site so amazing.  Simple solutions to complex problems.  Thanks for the tip.
Mar 17, 2010. 9:58 PMverybluesky says:
Here's my first tree.
Mar 17, 2010. 9:06 PMverybluesky says:
Thank you for sharing this instructable.  I made my first tree and here's a picture.  I didn't use a lot of wire since I was eager to finish it.  There are only 3 roots but it can stand up by itself.
Mar 13, 2010. 11:31 PMCylvre says:
My grandmother had a very large and full one of these on a wind-up rotating musical base.  This bring back wonderful memories.  Will definitely be filing this one away for future use.  5 stars!  Thank you for sharing.
Mar 13, 2010. 9:46 PMChrysN says:
Nicely done!
Mar 15, 2010. 5:08 PMlady4feet says:
They look great! Thank you for posting this. How did you attatch the tree to the rock?
Mar 15, 2010. 2:16 AMcokecola says:
Cool! I have made a few of these ming trees and after twisting the wires for  a while my wrist would snap with each turn. I put a hook in the end of a dowel and would hook it into the "leaf" and rotate the dowel to twist it wires. It worked well for the smaller branches.
Mar 14, 2010. 7:24 PMTheFawns says:
 this is freaking awesome :DD i am gonna make my girl one of these :) the tree is gonna be shaped like a heart :D if i make it, ill post it on here
Mar 14, 2010. 6:29 PMnickodemus says:
I made something similar to this once. It had a metal nut for the base instead of the rock and had smaller metal nuts on the limbs to act as fruit. I'll try to put up some pictures later. Great Instructable too.
Mar 14, 2010. 11:42 AMmdeblasi1 says:
I've been thinking about something like this for a long time.  It just seemed like soooo much work, especially since I was apparently trying to reinvent the wheel.  Never the less, I had the idea of using a small torch to ball up the tip of each wire, so that, flattened with a hammer, it looked like a leaf.
Building a patina from water oxidation sounds like a good idea,  There is also a simple peanut oil patina that I've seen on copper that gives it a lovely dark wood tone.
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:Elizabita(Deliciously Knotty)
