3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Two Bladed Pocket Knife
Make A Two Bladed Folding Pocket Knife Made From PVC & Hacksaw Blade.
Step 1Parts and tools needed
To make a Two Bladed Folding Pocket Knife you will need 1/2 " pop rivet, 2 washers, and "thin wall" Class 200 PVC . Time to make about 1/2 hour. Tools needed are hack saw, pop rivet gun, stove, sand paper, grinder (you can use a sharping stone rather than a grinder but it takes longer).
77 comments
1-40 of 77next »
Mar 28, 2012. 9:11 AMbioprodigy04 says:
Thats is awesome. sadly i dont have all the tools to make it :(
Feb 13, 2012. 5:15 AMheathbar64 says:
Seems to me like the pvc would wear and let the blades wobble around and fall shut. I wonder if you could use one of those spring washers between the blades. that seems like it would keep them the right tightness even when the thing wears a bit.
Feb 12, 2012. 9:03 PMapplesaucemodifier says:
Clever!
Jan 1, 2012. 1:10 PMGrimmy Grim says:
Thank you, I appreciate these sorts of projects and the nice layout that is step by step.
Dec 5, 2011. 11:56 AMghost999 says:
awsome
dude
Aug 21, 2011. 8:48 PMThe Mariner says:
If you arrange the saw blade so that it cuts on the pull stroke, rather than the push stroke like normal, it'll help prevent the blade from breaking.
Nov 23, 2011. 10:04 AMacoleman3 says:
hey yeah....like a japanese hand saw!
Aug 21, 2011. 7:32 PMilpug says:
seems pretty awesome, although i have tried making knives from hacksaw blades and they always snap. i would try this, but use old reciprocating saw blades.
Mar 28, 2011. 7:13 PMgary.918 says:
looks good. the blades will be a little brittle, but should work. well done
Feb 22, 2011. 3:35 AMteodoropires says:
extraordinarily good!
Nov 23, 2010. 10:51 AM(YOUR N says:
G567 MY NEW CODE NAME
Aug 11, 2010. 6:51 AMTALLJ29 says:
looks pretty cool and easy. Might have to try it when i get some time!
Sep 23, 2009. 5:59 PMDon,t try this at home says:
So how do you make the knife lock.
Jul 5, 2010. 3:44 PMdawsonj says:
when the top of the hacksaw blade hits the inside of the pvc it stops it from sliding more, but id doesn't lock the other way
Jun 11, 2010. 9:18 PMskimmo says:
have you tryed meccano for the handle?
Apr 30, 2010. 4:57 PMajjardin says:
Nice Instructions. very clear and precise. 2 bladed folding knife is very handy. i was thnking of making one with 2 saw blades. thanks for sharing
Spring Assisted Knives
Oct 23, 2009. 12:26 AMcloudrunnersurvival says:
I like it. Nice work. I make mini neck knives out of hacksaw blades as well.
I use a simpler technique they are part of a necklace kit I make.
But I really like this. These are up to $5 and you just made one for free basically.
Strong work keep it up. Peace
Aug 29, 2009. 12:01 AMweaponscollector94 says:
i made a few of these knives today i made one like the one in the picture but with a sharp point rather than a rounded one i also made a single bladed version (also sharp pointed) and then i made a folding fillet knife but with the same materials! i not only made the point on the blade but i polished the blade with a belt sander and then fie sand paper and it looks really professional! thank you so much for the idea by the way!
Mar 13, 2009. 2:10 PMtahirhh says:
if you have access to a laser cutter, you can make the sided bits on 2D Design
Mar 13, 2009. 12:59 PMajk97 says:
Does the knife stay open or is it loose and fall back into the handle? Thanks and great Instructable.
Jan 11, 2007. 6:14 PMberky93 says:
I'm in the process of making a metal version of one of these, but I realized that the knives will dull when they contact the metal over and over. What can I use to cusion them? I was thining of this rubber coating stuff, but I don't know what it is called and where to get it. help please?!
Dec 7, 2008. 11:39 AMl96470fps says:
y dont u use inner tube??
Jan 30, 2007. 10:59 AMVendigroth says:
i know i should leave you alone, but i just realised as i got home from college that if you use copper as the metal, the steel'd not be damaged cos the copper's softer
Jan 30, 2007. 8:12 AMVendigroth says:
er....try a little bit of papre, just folded and pushed into the handle, if that doesn't work try and get some thin leather or a piece of the sealing rubber off waterproof torches. or even an elastic band poked into the bit where the knife'd touch the metal
Feb 2, 2007. 6:12 PMreeding says:
take a swiss and cut off all but 2 blades
Jun 11, 2007. 6:09 PMchemy999 says:
or just take a swiss
Nov 30, 2008. 7:27 PMxenongamer says:
good. I might try this, seeing as my other knife got... broken... while i was trying to modify it. yeah, who knew that tungsten could destroy half the house.
Nov 28, 2008. 10:24 AMim so thirsty says:
i like the style i made one sorta like it expet was an otf swicth
Nov 28, 2008. 10:22 AMim so thirsty says:
and i mean the par were u bind the pvc
Nov 28, 2008. 10:21 AMim so thirsty says:
its realy cool but how do u get it to fold
Nov 10, 2008. 11:56 AMpumpkinman says:
extremly nice instructable, i used boilin water to bend my pvc pipe and that did not work so well. do you have any idea of what to make of the rest of the hack saw blade?
Nov 7, 2008. 4:49 PMLance Mt. says:
Boiled water. It does the job rather than a naked flame with toxic fumes.. Other than that, It's super sweeeet (making 1 now.)
Oct 3, 2008. 1:15 PMnfsaggese says:
Do you know how to make it a locking blade?
Sep 13, 2008. 10:52 PMled_scorched says:
very cool.. if i had more time, i would totally try this!
Aug 2, 2007. 10:34 PMMurdok says:
How do you pop-rivet? I need a substitute, any ideas?
Sep 12, 2008. 6:09 AMbob_shaftenkluger says:
Use a bolt?
Jan 29, 2009. 2:31 PMclemsonguy1125 says:
how much does a pop rivet gun cost
Jul 5, 2010. 3:46 PMdawsonj says:
eh, about ten bucks
Aug 21, 2008. 6:24 PMDIYerr says:
This is an exellent instructable. I am using the pvc material and method described here as a substitute to a kydex sheath for a very small neck knife I just started making.
1-40 of 77next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:Matin
http://www.webfun.org http://www.dometents.com http://www.gripclips.com http://www.relieftents.com http://www.primitiveways.com http://www.woodenbikes.com http://www.bobgillis.com
