Make a USB IPhone IPod Charger on the Cheap!
351,429
1,732
334
Posted in TechnologyUsb
Introduction: Make a USB IPhone IPod Charger on the Cheap!
About: I'm a youth pastor in Minnesota. I went to Cornerstone University and studied Bible, Youth Ministry, and Psychology. I'm a Maker hobbyist for about 10 years. It's fun to be Geeky.
There are many designs for iPhone chargers out there and many are confusing or use parts that are hard to find.  My design uses parts that are easy to find, is tested works with all iPhones and iPods (as of this posting), and just works.  It is a fun and useful project.  I made one a few years ago and put a video on YouTube.  I weekly get many questions about making one.  So here you go and i hope you enjoy it.
Step 1: Parts List:
Parts:
  • 1 - SPST Switch (I used a toggle switch)
  • 1 - LED for "ON" indicator red or green (Radio Shack sells LED's with resistor "350 ohm" you can mount.  That's what I used.)
  • 1 - 350 ohm Resistor
  • 1 - 7805 Voltage Regulator
  • 1 - 22uF Capacitor
  • 1 - 10nF Capacitor (code 103)
  • 2 - 33K Resistors
  • 2 - 22K Resistors (Other values can be used, read step 2)
  • 1 - Female USB Connector (I got mine at a dollar store)
  • 1 - 9v Connector
  • 1 - 9v Battery
  • Electrical Tape
  • Solder
  • Soldering Iron
  • Small piece of perfboard
  • Altoids Tin
  • Dremel Tool with cutting attachment or tin snips to cut the tin
  • Drill for switch and LED hole
  • Hot Glue
  • Paint if you want
You can go here for a good tutorial on soldering.
For most of the parts you can use techno scrap and recycle old broken electronics or just buy them.
I wanted to use parts that are easy to find and inexpensive so everything can be bought at Radio Shack or if your don't mind on-line shopping I like http://www.taydaelectronics.com/servlet/StoreFront because it's cheep!
I hope you enjoy the project.
Warning: Just a fair warning that there is a small chance that something can go wrong and you can end up frying your really expensive iPod.  Be careful.
Step 2: How Does It Work?
All USB plugs run at 5v so need a way to make a portable 5v charging device.  There are a few ways to do this.  The way we are going to do it is to use a 9v battery and reduce its voltage to 5v with a 7805 voltage regulator.  First, i like toggle switches and LEDs, the switch is placed first near the battery to ensure it's not running when not on.  Then the LED (on indicator) and resistor before the regulator, but on ether side of the regulator a capacitor is placed to smooth out the current a bit.
For most USB charged devices this would be enough.  Just attach the red and black wires from the USB and it should work, but  Apples iDevices have a feature that tries to stop people like us from making our own charger or using most other non-Apple chargers.  The iPhone or iPod Touch needs to "see" a 2v charge in each of the 2 USB data lines as a, "OK, this charger must be from Apple so it's time to start charging from the 5v."  This is why you need the extra resistors to make a voltage divider to make the 2v because  22K / (22K+ 33K) * 5.0V = 2.0V.  When I made mine I used the 22K and 33K values but you can also use 2 50K and 2 75K or 2 100K and 2 150K to also reach 2v.  Let me know in the comments if those other values actually work, I think they will.
I have tested this charger with a few iDevices including an iPhone 4.  For iDevises the charger will work until the 9v battery gets down to around 6v or 5v.  Then you will get a message saying "Your iPhone does not recognize this charger."  You may not get a whole charge out of a battery, so it is great to keep for emergencies.  This charger can charge much more than iDecives.  I have used it with other MP3 players, cell phones, cameras, and video cameras.  Really anything that can be charged with a USB.  That really was helpful when my kids were being cute and I wanted to video tape them but the recorder was dead.  Just plug it in, carry it along, and catch those precious moments on video.
Step 3: Putting It Together
  • Use your Tin to lay it out your pattern to make sure your wires are the right length.
  • Solder the red (positive) wire from the battery connector to one pin of the switch and from the other pin to the perfboard.
  • Solder the black (negative) wire from the battery connector to the perfboard also.  So now you can have a positive and a negative side.
  • Attach wires to your LED long enough to put it where you want it.  Solder the positive LED lead to the board with the positive wire.
  • The LED negative side has a small flat spot on the side of the plastic.  Attach that wire to the 350 ohn resister.
  • Then the other side of the resistor to the negative side of the board.
  • Place the 22uF Cap in the board.  The side with the line on it is the negative side and goes to the negative wire.  The other is positive and attaches to that wire
  • Now comes the 7805.  If you look at the front of the chip, the left pin is attached to the positive wire in your board (which is from the 9v battery), the middle pin is ground and is attached to the black (negative) wire, and the right pin is 5v out which will be the positive source for the rest of the circuit.  (see diagram for pinout)  You can see in the pictures i used a heat sink on the 7805 but that is not necessarily.
  • Then add the little 10nF cap to the negative (ground) and the positive 5v.
  • Now comes the voltage divider.  You need 2 33K resistors connected to the positive 5v and each of those are connected to a 22K resister which is then connected to ground (negative, black).
  • Almost done
  • Now the Female USB.  If you get one with wires still on it will be a little eaysier.  If not just attach your own wires.  The red wire needs 5v and the black needs to go to ground.  The green and white wires each need 2v and are attached between the 33K and 22K resistors.
  • Plug in the battery, the iPhone/device, and turn it on :-)
Step 4: Prep the Tin
If you make your charger like mine (which you don't need to) you will need to drill 2 holes, one for the switch and the other for the light.  Then you will need to cut a rectangle hole for the USB.  I used a Dremel with a cutting wheel.  I also spray painted mine red.  It took a few coats to get it all.  To prevent the circuit from shorting put some black electrical tape on the inside on the tin.
Then just install all the circuit guts, use a little hot glue to hold down the USB and you're good to go.
Step 5: More Information
For more Information you can check out.
My YouTube Chanel for more techie videos :-)
The Mysteries of Apple Device Charging.  With a Cool Video.  Thanks Lady Ada.
I
f you have questions you can leave them in the comments and i'll do my best to answer them.
Pocket-Sized Contest
Runner Up in the
3 People Made This Project!
  • Microcontroller Contest
  • Casting Contest
    Casting Contest
  • Make it Move Contest
334 Comments
I made one similar to this but I took the circuit board out of a car USB cigarette lighter plug. I then attached two 9 opt batteries in series to give me 18 volts, which the charger can run on to power the circuit board.
This looks really simple! Did you have to insulate the tin to keep it from shorting?
I was wondering. A 9v battery doesn't facilitate sufficient mAh. So, would it be possible to use other batteries e.g. 4200 mAh 3.7v. The battery is high drain rechargeable though. Would use of such batteries be feasible? Is it possible through changing the circuit?
I fly RC airplanes and I use li-pi batteries.a lipo battery the size of a nine volt will run day or two and charger will cost under twenty bucks in long run you save tons and have way more charge.my battery is size of the tin and runs about three to four days.take fifteen mins to recharge lipo BP hobbies and dealxtrem have good cheep lipo.cellphones don't use much so 10c is fine don't need high discharge rate like airplanes
how do you cut the perfboard for the circuit board?
This is very good project. I also have made some changes with original circuit. I used resistor of 330 ohm instead of 350 ohm resistor and 10uF capacitor instead of 10nF capacitor and it's working great.Highly recommended for those who need cheaper power banks for outdoor use.
Made it with my students (16 years old) ! Worked great !
Why would it fry you device and what would cause this?
ref: "on ether side of the regulator a capacitor is placed to smooth out the current a bit." Why?
Your power source is a battery. Unlike a rectified AC source, there shouldn't be any ripple. Or am I missing something?
The painted tin is quite nice! ;-)
Using capacitors like this, even when running off battery power, is just good practice. There's more to it than just rectifying ripples in the power source. They also serve to filter out noise from the device being charged from interfering with the voltage regulator.
True, this circuit would probably work 99% of the time without the capacitors, but it's a good idea to include them.
I see. Thanks!
Just my 2 cents but I wouldn't think too many. 9v alkaline batteries don't hold a lot of juice. Only about 300-500 mAh at 9 volts depending on current drain and the iPhone 4s battery is just shy of 1500 mAh at around 3.6v I think. I don't know the math but I would guess less than one full charge.
I' be just started teaching myself electronics, and I was wondering why you need so many parts or why you don't just have larger resistors. Is there a reason ?
This method is more slightly efficient than using a large resistor and also works independent of load. basically if you have a regular phone that may draw only 1 amp and a tablet that could draw 2 aps, this circuit will provide 5v to both of them, where as a resistor will push too much voltage into the tablet. There's actually an even better solution called a switch-mode power supply. Though those are not simple or cheap. I encourage you to learn as much as you can about electronics! Don't be afraid to spend hours on the web breading things.
Awesome project! Does it work on the newest iPhone and iPad?
Did a similar build but used 2 9V in parallel and a 12V car usb adapter. Stripped the adapter down and glued it into a tin. Picked up a toggle switch at Radio Shack and it worked great.
Hello I am doing somthinlike your project but what I was planning is make the charger being able to connect to a connector in the wall but I am not really sure how to... do you think you can help?
My first real circuit. I made a lot of mistakes but they were worth it for the knowledge gained. I liked this instructable because it's totally functional, it looks cool so you can show it off to your friends, and it was just challenging enough for a beginner. Thanks man!
