Although everything you need to know is in the pictures, the video tells the whole story just as well…
If the video is not playing, have a look at it here...
All you need to know to build this low-pressure kid's gun is described in the texts, as well as in the comments with the pictures. Have fun building and shooting! But please be careful, don't point your self made bazooka to living creatures.
Remove these ads by
Signing UpStep 1Stuff you need
- A vacuum cleaner. Any model will do.
- Straight piece of PVC tube, at least 1 meter long. Longer is better (see the text on tweaking)!
- Inner diameter 35 mm (1.4").
- A PVC 3-way junction with an angle of 45°, that fits the straight PVC tube.
- Duct tape.
- A projectile: I used the plastic capsule that is inside "surprise-eggs" (see picture). Old school film containers work as well. Whatever you use, make sure that the projectile's diameter is just a little smaller than the PVC tubes'.
- A small piece of cardboard (business cards are perfect).
Home Depot didn't carry a 45 degree 1-1/4" Y or T joint, so I went with a regular 90 degree Tee. I used a 1" elbow to get some angle on the inlet. The 1" elbow fit tight enough inside the 1-1/4" T. I didn't use cement on any of the joints.
I tried 2 different lengths for the projectiles (about 6" and about 3"), with and without sand for weight. They seemed to fly farther without the sand. I also tried a shorter launch tube - 2 ft instead of 3 feet. The longer tube launched them farther as well. I didn't measure, but it was probably in the 50-60' range, depending on the angle.
The ID of the 1" elbow was a good fit for my vacuum cleaner's hose, so I didn't need any tape there.
Thanks for posting a great instructable! Hope you win the contest!
Vince
hehe
greets
Have fun! Neil A Downie
I couldn't find the PVC Y fitting at Lowes either. BUT... they do have them in the black sewer pipe section!
After reading this instructable, I made mine with leftover parts lying around the shop using: a BIG shop vac, a 4.5 foot long metal pipe, and Gorilla Tape.
I sent a 35mm film canister filled with flower about 140 feet on the first try.
The only [other?] thing I did differently was to put a small hinge on a very thin strip of brass to act as the "stopper" [?] on the muzzle end, so I did not need to have a pile of business cards, or scamper to find the last one that wsa shot off the end.
Man, whas that ever fun, but my Dogs hate me now!!!
MWWWAAAAHHAHAHAHAHA!
The Trouble I could get into is ENDLESS!!
"Vacuum Bazookas, Electric Rainbow Jelly and 27 other saturday science projects", by Neil A. Downie?
I think the vacuum cleaner bazooka just MIGHT be in there, too :D
ISBN 0-691 00986-4
Y.
Bold is ISBN number
Steve
So I think I can say that this is very cool! And if you add a hinge to the business card with a travel stop so it can't open any further than 90 degrees, the suction will pull it closed and you could have a rapid second shot.
I used 3/4 inch PVC pipe, with paintballs.
Adding a travel stop to the card is a smart idea. If that works, a cartridge containing several projectiles can be added, too...
A travel stop mod would be easy to add to your existing bazooka. A hinge can be a piece of duct tape. The stop itself, a piece of coat hanger wire bent into a U and taped to the side of the muzzle, right over the tape hinge.
But that would be the easy way. I would like to see a 6-inch section of 2 x 2 square tube hot-glued across the muzzle. Entry & exit holes right through the center and the hinge taped into place on the inside so that the tape is neatly out of sight and stuck firmly on a large flat area. This would have a much nicer appearance, like a Barret .50 rifle.
can it launch a small potato too?
THX for the awesome, and awesome-ly simple, 'ible!
