3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Vacuum-cleaner Bazooka
In five minutes, you can build an air-powered bazooka. The bazooka launches plastic capsules about 100 feet. And with some tweaking, you might stretch that distance quite a bit.
Although everything you need to know is in the pictures, the video tells the whole story just as well…
If the video is not playing, have a look at it here...
All you need to know to build this low-pressure kid's gun is described in the texts, as well as in the comments with the pictures. Have fun building and shooting! But please be careful, don't point your self made bazooka to living creatures.
Step 1Stuff you need
Stuff you need
Stuff you need:
  • A vacuum cleaner. Any model will do.
  • Straight piece of PVC tube, at least 1 meter long. Longer is better (see the text on tweaking)!
  • Inner diameter 35 mm (1.4").
  • A PVC 3-way junction with an angle of 45°, that fits the straight PVC tube.
  • Duct tape.
  • A projectile: I used the plastic capsule that is inside "surprise-eggs" (see picture). Old school film containers work as well. Whatever you use, make sure that the projectile's diameter is just a little smaller than the PVC tubes'.
  • A small piece of cardboard (business cards are perfect).
91 comments
1-40 of 91next »
Jul 15, 2011. 6:48 PMbloomautomatic says:
Here's how I did mine. I used 1-1/4" sch 40 PVC pipe for the launch tube, and 3/4" sch 40 PVC pipe with caps for the projectiles. They fit perfect with no modifications.
Home Depot didn't carry a 45 degree 1-1/4" Y or T joint, so I went with a regular 90 degree Tee. I used a 1" elbow to get some angle on the inlet. The 1" elbow fit tight enough inside the 1-1/4" T. I didn't use cement on any of the joints.
I tried 2 different lengths for the projectiles (about 6" and about 3"), with and without sand for weight. They seemed to fly farther without the sand. I also tried a shorter launch tube - 2 ft instead of 3 feet. The longer tube launched them farther as well. I didn't measure, but it was probably in the 50-60' range, depending on the angle.
The ID of the 1" elbow was a good fit for my vacuum cleaner's hose, so I didn't need any tape there.
Thanks for posting a great instructable! Hope you win the contest!
Vince
Jul 18, 2011. 10:57 AMShadetree Engineer says:
A good example of matching the energy level of your vacuum system to the weight of a projectile. If you wanted to find the ideal length of tubing to use for a projectile, you could try firing the tubes into a cardboard box that has a pillow inside. Then measure how far the box slides on each shot. I would add some packaging tape to the bottom of the box, because the amount of force to get the box to start moving needs to be both low and consistent over many shots.
Aug 9, 2011. 12:41 PMNightHawkInLight says:
This is really awesome guys, way to go on winning the challenge!
Feb 15, 2012. 7:41 AMneologik says:
excelent!!! very good .. does this work with water baloons?
hehe
greets
Sep 12, 2011. 12:46 PMthejevans says:
All I see is an unfinished Airsoft RPG Launcher. fill the egg with BBs and an m120. Stick the fuse out of the bottom of the egg. Light the fuse, and shoot the egg. Lots of experimenting with timing would be necessary, but I think the end result would be worth it.
Sep 4, 2011. 10:12 AMneil a downie says:
The Vacuum Bazooka is indeed in my Vacuum Bazooka book- and the rapid fire multiple projectile version is in my soon to be published book-Ultimate Saturday Science. I have 2 other books - Ink Sandwiches and Exploding Disk Cannons. You can see other projects on you tube (try nddownie) and on the Eli Whitney Museum website.
Have fun! Neil A Downie
Aug 17, 2011. 3:07 PMNachimir says:
So lovely, and simple. Thanks :)
Aug 5, 2011. 1:39 PMPS118 says:
For whatever reason I can't reply to bloomautomatic's post, but...
I couldn't find the PVC Y fitting at Lowes either. BUT... they do have them in the black sewer pipe section!
Jul 29, 2011. 8:51 AMdylankunaikennedy says:
could i make it with a 90 degree elbow piece?
Aug 2, 2011. 10:01 AMdylankunaikennedy says:
instead of a 3 way connector?
Jul 26, 2011. 12:53 PMavatar_i says:
That is completely incredible!
After reading this instructable, I made mine with leftover parts lying around the shop using: a BIG shop vac, a 4.5 foot long metal pipe, and Gorilla Tape.
I sent a 35mm film canister filled with flower about 140 feet on the first try.
The only [other?] thing I did differently was to put a small hinge on a very thin strip of brass to act as the "stopper" [?] on the muzzle end, so I did not need to have a pile of business cards, or scamper to find the last one that wsa shot off the end.
Man, whas that ever fun, but my Dogs hate me now!!!
Jul 26, 2011. 12:57 PMavatar_i says:
I wonder what would happen if I used an old belt driven compressor with a 4" piston, weighing about 85 pounds...
MWWWAAAAHHAHAHAHAHA!
The Trouble I could get into is ENDLESS!!
Jul 23, 2011. 10:32 PMdawsonj says:
AWESOME! AWESOME! WAEOSEM! wish I thought of this!
Jul 22, 2011. 1:00 PMevilmadcow says:
suuuweeeett.
Jul 14, 2011. 7:26 AMsteveastrouk says:
From Bill Gurstelle's book "Backyard Ballistics" ! An excellent instructable. We did it with water filled 35mm film cans- a really nice fit in standard pipe.
Jul 22, 2011. 12:56 PMevilmadcow says:
good idea. I live in the U.S. so getting an egg like that would cost a fortune.
Jul 14, 2011. 11:59 AMsteveastrouk says:
Sorry, my bad, wrong book, its http://www.amazon.co.uk/Bazookas-Electric-Rainbow-Saturday-Projects/dp/0691009864
Jul 21, 2011. 2:30 AMsteveastrouk says:
That's the one in my link above your comment. http://www.amazon.co.uk/Bazookas-Electric-Rainbow-Saturday-Projects/dp/0691009864
 Bold is ISBN number
Steve
Jul 22, 2011. 2:42 AMdanielthomas72 says:
Hey there, I made a version of this with the kids on the weekend!! Brilliant!! Thanks for posting, it was so simple that they were able to assist with most of the construction.... absolutely ingenious!! Cheeeers!
Jul 15, 2011. 2:27 PMastrong0 says:
what if you used a shop vac....
Jul 21, 2011. 5:35 AMsteveastrouk says:
Range over 200 feet.
Jul 19, 2011. 4:57 PMThe nerdling says:
deadly
Jul 15, 2011. 12:20 AMShadetree Engineer says:
http://www.instructables.com/id/Automatic-Vacuum-Powered-Paint-Marker/
So I think I can say that this is very cool! And if you add a hinge to the business card with a travel stop so it can't open any further than 90 degrees, the suction will pull it closed and you could have a rapid second shot.
I used 3/4 inch PVC pipe, with paintballs.
Jul 18, 2011. 10:40 AMShadetree Engineer says:
'weapon' is an overstatement, it had trouble breaking all the paint. But using a continuous flow of air to move projectiles looks promising. My goal is merely to get 300 FPS, all other serious research in a device like this was to get over 1000. 300 is the legal limit for playing fields.
A travel stop mod would be easy to add to your existing bazooka. A hinge can be a piece of duct tape. The stop itself, a piece of coat hanger wire bent into a U and taped to the side of the muzzle, right over the tape hinge.
But that would be the easy way. I would like to see a 6-inch section of 2 x 2 square tube hot-glued across the muzzle. Entry & exit holes right through the center and the hinge taped into place on the inside so that the tape is neatly out of sight and stuck firmly on a large flat area. This would have a much nicer appearance, like a Barret .50 rifle.
Jul 17, 2011. 5:56 AMfreakyqwerty says:
Wow that looks awsome! How long does it take for Hoover to create a vacume in the pipe?
Jul 16, 2011. 10:29 PMsitzikbs says:
Great job guys! it looks awsome!
can it launch a small potato too?
Jul 15, 2011. 10:32 PMpayman says:
Thanks, this is very interesting...!
Jul 14, 2011. 6:20 AMmrmath says:
Kinder Eggs are illegal in the US :( I guess you'd have to substitute small water balloons :)
Jul 15, 2011. 3:14 PMklindner says:
I read the wiki link. . . and I still don't believe it, I juuust walked out of a VONS 10 minutes ago which carried them. There are also identical Korean and Japanese knock offs at Asian specialty stores all over.
THX for the awesome, and awesome-ly simple, 'ible!
Jul 14, 2011. 6:32 AMbradhowes says:
What?! We bought them all the time in Cambridge, MA. Are you serious?
1-40 of 91next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
70
Author:ynze(www.slimme-handen.nl)
Inventor of mostly useless and sometimes funny Stuff... I use the stuff I make during workshops with kids and teachers.
