Make a Viking Chair With Hand Tools!
Introduction: Make a Viking Chair With Hand Tools!
These chairs are really fun projects that are cheap, easy and make great additions alongside a campfire. They are also known as bog, plank or stargazer chairs. Due to the angle and length of the back, these chairs really support your neck while you look up at the stars and are surprisingly comfortable! See more info about this project and others at .
I wanted to make these in a more traditional fashion, without power tools. It takes longer but is very satisfying! So grab a mug of your favorite mead and an axe and let's get to work!
(Clicking the links below and purchasing anything on amazon helps support JDIY, and it doesn't cost you anything extra!)
Hand tool list
Lawnmower blade, Froe or a strong, sharp, strip of metal to split wood with
Hand saw
Mortise chisel
Brace and large auger bit (you can find cheap vintage braces at yard sales / ebay. also make sure that your bits are sharp)
Rubber Mallet
Tape measure
Saw horses
Lumber list
2"x12"x8' Pine board for each viking chair
Viking list (some would say these are optional)
Viking drinking horn
Beverage of choice
Step 1: Cut the 2x12x8
The first step in making a viking chair is to cut your 8 foot boards in half to 4 feet. Use your hand saw and saw horses here and it really helps if you can put a foot down on the boards so they don't move around when cutting.
Step 2: Mark and Cut the Mortise
Mark your mortise slot, make the slot about 12" from the bottom of the board, and 8 inches wide. Measure lines 2 inches in from either side so that your slot is centered. Place the other half of your board standing up over the mortise line and mark again. Now your mortise will be the exact 'thickness' of your board for a close fit. See the diagram in the first step for reference.
Attach the largest bit you can find to your brace and drill out the center of the mortises, where the X's are above. Have a friendly viking sit on the board to keep it steady, and watch the shavings fly! Make sure to put a scrap board underneath where you are drilling, to prevent tear out and splinters.
Clean up the mortise with your mortise chisel & rubber mallet. It doesn't need to be perfect to start, cut it a but undersized and check your fit.
Step 3: Cut Notches and Split the Wood With the Lawnmower Blade!
Mark your 2" offsets on your second board and cut them with a hand saw. These should be about 12" from the end of the board. See the diagram at the bottom of the post for details.
Now here comes the fun part. A true viking doesn't need to cut wood, he splits it with an axe! Use your mallet and hatchet to begin splitting (get the split started) the wood at the opposite end of the offsets you just cut, about 2" from the side of the board. The wood will split right along the grain, so line it up parallel with your offset. You don't want the wood to split too far towards the center of the board, or it will be a loose fit.
Next, use your metal hammer and the lawnmower blade to finish the split. Wood splitting is also called 'riving'. Clean up the remaining excess with your hatchet and check your fit. Finally, fit the viking chair pieces together. Finish with some stain and you can add some deck sealer to the chair if you plan to keep it outdoors.
Cheers and long live Odin!
  • Pocket-Sized Contest
  • Science of Cooking
    Science of Cooking
  • Paper Contest 2018
    Paper Contest 2018
I love it! the blond braids, horned helmets, sense of humour and playfulness to the finished project! makes me want to go out and split boards with an ax!
Glad you liked it! Its a fun way to spend an afternoon :)
enter this in the hand tool contest, vikings like booty, eh?
