3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Water Sensor
Make a Water Sensor
Learn how to make a water sensor for when it rains if u want to turn something on or make the sensor warn u for a flood in the basement.
Step 1Cutting the Foil
Cutting the Foil
Cut the aluminum foil so it is the correct length [the same size as one side of the insulator]
16 comments
Jan 14, 2012. 8:19 AMdiy_bloke says:
great idea. A washer under the screwheads might help making good contact without tearing the foil
Dec 27, 2008. 10:42 AMfwjs28 says:
use FireFox...built in spell checker...Instructables even has one....
Mar 11, 2008. 5:31 PMinventivefiend says:
I really would prefer standard English. If it is not your first language, I can make an exception. But the 'l33t sp33k' gets old quickly.
Nov 3, 2008. 5:50 PMmightywombat says:
I absolutely agree 150%.
Nov 1, 2008. 8:32 PMcfm says:
I think you will find that water is too poor of a conductor for this device to act like a switch for any load greater than maybe an LED. You could connect it to a high-gain transistor circuit and drive a relay that could drive a heavy load. It certainly would not pass enough current, even at 120VAC, to drive a sump pump. (It should not be used at that high of a voltage. Having 120VAC sitting in a puddle on your floor is inexcusably hazardous. I would not exceed 12 Volts for safety reasons.)
Oct 4, 2008. 7:45 AMDBLinuxLover says:
Good instructable. But would you please stop using "u" in place of "you"? It gets on people's nerves
Apr 3, 2008. 3:11 AMmonisha says:
How does it works? Water should be poured on both part of the foil? Device in the figure can be anthing? Can it be a motor or a waterpump? please reply
Apr 3, 2008. 4:46 PMPatented says:
When the water go on the foil(in the middle) it connect the two sides so it make the electricity pass(its like a switch).And yes it can be anything else then a device, but check your voltage for other thing that u connect to it.
Apr 5, 2008. 8:26 PMmonisha says:
thankyou
Mar 20, 2008. 12:02 PMLego man says:
I thought it was pronounced Battery not batterie, batterie is past tense plus it needs an s at the end to make it past tense, and my goodness I'm confusing myself. "Batteries"
Mar 15, 2008. 6:54 AMSkip says:
I like this instructable, though I do have a suggestion with the screws. Adding a washer or nut to the screw might increase the chance of the aluminium foil surviving longer.
Mar 12, 2008. 1:38 PMnagutron says:
Why the interesting pattern cut out of the tin foil?
Mar 11, 2008. 4:45 PMGorillazMiko says:
Very good Instructable. I don't have a basement, so I don't have to worry, but great job!
Mar 11, 2008. 7:06 PMtyeo098 says:
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:edfel01
