Introduction: Make a Wi-Fi Extender
Plagued by unreliable Wi-Fi connectivity? Just found a cheap and relatively easy way to boost a wireless routers signal strength by creating a simple parabolic reflector dish to direct Wi-Fi signals to your intended receivers.
follow me on twitter! http://www.twitter.com/rohanlikhite
Visit my site => http://rohanlikhite.com
Step 1: Gather Required Materials
Step 2: Assemble Your Wi-Fi Extender
Print out the template on a sheet of regular paper. You can actually scale the image to a larger sizewhile maintaining the relative dimensionsfor a stronger focus. First, cut out the template pieces, then use a glue stick to affix foil to the front of each piece. Use a knife to make cuts on the indicated slits and bend the reflector to fit the six tabs into the respective holes.
Step 3: Attach Onto the Router
Slide the booster over the existing antenna of your router and point it in the desired direction.
